need advice on setup
Old Jan 17, 2002 | 09:43 PM
SamB16's Avatar
Default need advice on setup
ok, here is the situation. Currently putting together an el-cheapo budget turbo kit for my DA. Currently the car has a B16 under the hood with a pair of R cams. The setup is gonna simply be mitsu 14b with a 24" FMIC. Daily boost levels @ 8psi, all stock internals.
my question is this, I don't really like the idea of running huge fuel pressures which would be required when using an FMU and stock injectors.
I wanted to know if would make more sense to use some 440cc injectors and an FMU with like a 6:1 ratio and a fuel controller for idling and smoothing out the curve.
Any suggestions or alternative setup ideas?
awdriscol4
Jun 16, 2005 08:19 AM
99Sivic
Oct 27, 2004 06:04 AM
Rah Rah
Feb 24, 2003 06:03 PM
mannysir
Sep 8, 2002 05:49 AM
jmad08
Jul 30, 2002 10:02 AM
