should there be a gasket between manifold and turbo ?
Re: should there be a gasket between manifold and turbo ? (The Shodan)
Welp.. that didn't really help since the turbo doesnt connect directly to the block.
You don't necessarily have to use a gasket, but if the mating surfaces are not completely flat, then you will have leakage. It's better to use one if possible.
Re: should there be a gasket between manifold and turbo ? (Vanilla Ic3)
can someone tell me which way you point the Garrett gasket? does the lip of the gasket, the part that is pushed out from the flat surface stick up toward the manifold or down against the turbo?
Re: should there be a gasket between manifold and turbo ? (integra-modder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra-modder »</TD></TR><TR><TD CLASS="quote">can someone tell me which way you point the Garrett gasket? does the lip of the gasket, the part that is pushed out from the flat surface stick up toward the manifold or down against the turbo?</TD></TR></TABLE>
anyway will work.
stan
anyway will work.
stan
b18b1hmtlove
02-24-2004 06:18 PM
1.8T_EG
09-12-2003 07:00 PM
