FJO/Hondata lamda datalogging problems...
Old Oct 18, 2002 | 10:00 PM
boosted hybrid's Avatar
Default FJO/Hondata lamda datalogging problems...
I have tuned with my FJO unit and hondata stage 4b a few previous times. I know that the unit did work, and that the sensor worked when i used it a month ago. I spun rod bearings in my previous engine and the car sat for an entire month till i got the time to build another engine, and install it. Its been over a week since the new swap has been installed with all the turbo stuff, and i decided tonight was a good night to tune the car. I hooked everything up and went out with the rom editor open, hit connect and my lambda values were stuck at 19.5:1, 3.75 volts. I checked the oxygen sensor, all connections, checked for power into the FJO blackbox all seemed good. I check the 1000K ohm resistor, and it provided the correct resistence. I am assuming that the signal coming out of the FJO blackbox is bad, which leads to my question...Is there anything i am missing? Can the FJO blackbox go bad? I am totally stumped on what is going on, especially since it worked so well before.
Old Oct 18, 2002 | 10:09 PM
racerxadam's Avatar
Default Re: FJO/Hondata lamda datalogging problems... (boosted hybrid)
you should undo the connections from the fjo to the stock o2 harness and test the output from the fjo with a multi meter. that will let you know if rom editor or honda logger is reading the right voltage or if there is a problem between the black box and your ecu.
mtber
Engine Management and Tuning
24
Apr 16, 2014 08:09 PM
civic disobedience
Sep 3, 2002 08:51 PM
GruvyTune
Apr 20, 2002 04:11 PM
2000Si-at-UK
Feb 22, 2002 08:06 PM
