What compression level for 6lbs-7lbs?
Old Oct 18, 2002 | 10:57 AM
Racer X's Avatar
Default What compression level for 6lbs-7lbs?
Hi had a few questions. First, Do I need to lower compression for 6 to 7 pounds of boost on a B18C1? If I go any higher, can I just stick with the same compression and run a higher octane gas to prevent detonation (and replace my pistons with forged, but same specs as my cast ones)? I was looking at hondmod2.com and there was a post about this but I thought maybe you all could answer it better then people there could. Thanks for the help.
Old Oct 18, 2002 | 11:09 AM
MatT3T4's Avatar
Default Re: What compression level for 6lbs-7lbs? (Racer X)
You don't need to lower the compression period. You can run 7psi easily...and when you want more, introduce more fuel and tune accordingly.
Old Oct 18, 2002 | 11:28 AM
ajabbar's Avatar
Default Re: What compression level for 6lbs-7lbs? (MatT3T4)
6 n 7 pds in a b18c1 should be just fine with stock internals, and stock compression. If you are aiming for over 11pds then that is when I say build ur **** other then that you are fine.
Running925
Jan 1, 2008 06:39 AM
CivicDude2k4
18
Oct 8, 2006 09:13 PM
madcrossover
Dec 13, 2004 06:40 AM
Soon_2b_evil
Nov 16, 2003 07:41 PM
genop
Sep 17, 2003 10:45 PM
