Modify combustion chamber- To do...or not to do.
Old Oct 20, 2002 | 08:57 PM
rondigs's Avatar
Default Modify combustion chamber- To do...or not to do.
Just wanting some (supported) opinions.
Unfortunately I never anticipated going full sleeved to 84.5mm...before I had the head work done. As the head is now(B16): DPR valve springs, DPR valve job (ITR intake valves porcilin coated-oversized SS exhaust), the head has also been P&Ped and port matched.
Now, the question is: Should I go back and get the combustion chamber modified to correlate with the oversized (84.5mm) LS block?
Old Oct 20, 2002 | 09:29 PM
VaporTrail's Avatar
New User
Default Re: Modify combustion chamber- To do...or not to do. (rondigs)
if you've already got headwork, i wouldnt mess with it. The benefits aren't worth the cost. But if you are going to get head work, i do recommend it.
Old Oct 20, 2002 | 09:32 PM
rondigs's Avatar
Default Re: Modify combustion chamber- To do...or not to do. (VaporTrail)
Yeah, I've already done all the work mentioned.... Just wondering how much (and what) benefits it would net.
Old Oct 20, 2002 | 09:39 PM
VaporTrail's Avatar
New User
mainly it would give you a quench area that matches the bore, important for combustion quality and detonation resistance. Opening up the bore brings the sharp edges that surround the combustion chamber out of the combustion area, thus preventing detonation. Downside is, opening the chamber lowers compression, though that could be a possible upside for you depending on your situation.
Old Oct 20, 2002 | 09:49 PM
blkDOHCsol's Avatar
New User
search archived topics..there was a really good thread on this a while back
Old Oct 20, 2002 | 10:30 PM
*Boostwerks*'s Avatar
.....is wondering the same damn thing
Old Oct 20, 2002 | 11:07 PM
accordfreak's Avatar
Default Re: Modify combustion chamber- To do...or not to do. (Bryson)
in... for updated answers
Old Oct 21, 2002 | 12:18 AM
riceboy's Avatar
Default Re: Modify combustion chamber- To do...or not to do. (accordfreak)
VaporTrail pretty much broke it down to the bare facts. My humble opinion is to go ahead and do it if your gonna have the engine apart, cause of the detonation resistance. but if you have a standalone of some sort with a good knock sensor, then just kep tabs on it.
As far as mixture quality goes, that is a long discussion, and it's 3:18 am, so no book typing from me.
Old Oct 21, 2002 | 03:11 PM
rondigs's Avatar
Default Re: Modify combustion chamber- To do...or not to do. (riceboy)
Talked with viren....Thinking of just leaving as is. Noticed someone with similar setup running 500hp. Thats inspiring. We'll see how it goes....I plan on doing extensive tuning to prevent any unwanted outcomes
Just for reference, what is the "going rate" for combustion chamber modifications
Old Oct 21, 2002 | 03:54 PM
salt's Avatar
I'm doing the 84.5 thing too. I think with my head (b16) I'm just going to round off the cc edge by hand. Nothing major, just mark it and radius that corner to remove a potential hot spot.
steve
Old Oct 21, 2002 | 04:03 PM
rondigs's Avatar
Default Re: Modify combustion chamber- To do...or not to do. (salt)
....thinking the same.
NUISANCE
Jul 2, 2010 06:56 PM
earl
Jan 22, 2003 06:36 PM
baonest
Jul 17, 2002 06:41 AM
VaporTrail
Feb 26, 2002 11:09 AM
VaporTrail
Oct 18, 2001 10:40 AM
