Cant Adjust Boost
Old Oct 17, 2002 | 01:35 PM
Fatty_1775's Avatar
Default Cant Adjust Boost
I have a deltagate wastegate that is supposed to be 7 - 9 psi. Screw is all the way down, but my gauge says that it at 9 psi, that is with the intercooler. How can I lower my boost? I have a rev hard stage 2 on a b16 in a 92 hatch. Here is a link to how it looks like. In other pictures, the wastegate points to the left and mine points up. It looks like it is installed right. Any help on how to lower my boost will be greatly appreciated. Thanks!!
http://www.cardomain.com/id/import_racer75
[Modified by import_racer, 10:35 PM 10/17/2002]
Old Oct 19, 2002 | 10:39 PM
Fatty_1775's Avatar
Default Re: Cant Adjust Boost (import_racer)
No one has any ideas or advice?
Old Oct 20, 2002 | 01:59 AM
austrian type-R's Avatar
The wastegate is supposed to boost minimum 7-9psi...you are having 9psi, so what is the problem?
I would check if there is another wg spring available. hm, not sure about this, but is it possible to give some washers on the spring, that the spring is more tight?
Old Oct 20, 2002 | 03:08 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Cant Adjust Boost (austrian type-R)
If you want to lower the boost, the screw needs to be backed all the way out.
art
cherroneballs
Mar 23, 2006 02:10 AM
SOHC_MShue
Mar 14, 2005 03:00 PM
yusoslo
Jul 12, 2003 08:01 PM
DOHCarp
Jun 29, 2002 11:30 AM
SlowB16
Apr 17, 2002 08:49 AM
