going to tap the intake manifold
Old Oct 18, 2002 | 03:40 PM
Aeka GSR's Avatar
New User
Default going to tap the intake manifold
I'm assuming theres some gaskets, do I need to replace them? How long does it usually take to take the intake manifold off?
Old Oct 18, 2002 | 04:49 PM
Brian_92GSR's Avatar
New User
Default Re: going to tap the intake manifold (Aeka GSR)
I would say it's the hardest thing to take off the motor. If you've never done it before, better plan for quite a bit of time.
Old Oct 18, 2002 | 05:10 PM
legendboy's Avatar
Default Re: going to tap the intake manifold (Brian_92GSR)
to make your job eaiser make sure that you have a small wratchet with an extention and universal. Small like 3/16 smal. (i think thats it) and if your not going from underneath have a couple before you tackel the brace thats underneath the intake mani
Old Oct 18, 2002 | 05:46 PM
Danger's Avatar
Default Re: going to tap the intake manifold (legendboy)
shouldnt take to long.....3 hrs both ways ?
Old Oct 18, 2002 | 05:59 PM
bruthaboost's Avatar
I've done it under an hour, but I already had the brace off from the rebuild.
Old Oct 18, 2002 | 06:58 PM
rOby's Avatar
Default Re: going to tap the intake manifold (bruthaboost)
that brace is horible!!! literally took me 4 hrs to take it off(mani), once the brace is off it takes about 45 mins...need small hands. if ur gonna be drilln for direct port, i have a gsr manifold already drilled that im tryn to get rid of cheap, hit me up
genuser
Feb 16, 2015 06:03 PM
quickda6
Welding / Fabrication
31
Dec 10, 2006 06:58 PM
migo
Jun 3, 2001 01:30 PM
