Pullin off turbo.....NEED SOME HELP!
Old Oct 18, 2002 | 07:28 PM
boostinb18's Avatar
Default Pullin off turbo.....NEED SOME HELP!
whats up guys? i am going to pull off my turbo probably this weekend, sell it and go bigger......but i have a few questions to ask....... 1st will a 94 gsr exhaust manifold fit on my LS in my crx??? i dont have the stock manifold anymore!! 2nd question i have to put in my 240 cc stock injectors....but i dremeled out my stock o rings for 450cc dsm injectors..... will the stocks still fit?? or will i have to go buy new ones (they are like 40$ for everything!)??? and last for my oil return line i need to block it off..... so could i use a rubber vacuum plug and just cap it off and put a hose clamp on it??? what would you guys suggest??? thanks a lot!! sorry for all the questions!
Old Oct 18, 2002 | 09:48 PM
shadowdawn's Avatar
Default Re: Pullin off turbo.....NEED SOME HELP! (boostinb18)
Hehe I'm pulling off my turbo too..... sorry I wasted space posting this, but nice to know I'm not the only one thats gonna be busting my *** taking the turbo off and sending it out to get rebuilt/shipped back to me all in the same week.
Old Oct 18, 2002 | 11:31 PM
accordfreak's Avatar
Default Re: Pullin off turbo.....NEED SOME HELP! (shadowdawn)
I"m interested also.. up
Old Oct 19, 2002 | 02:06 AM
boostinb18's Avatar
Default Re: Pullin off turbo.....NEED SOME HELP! (accordfreak)
hahaah all three of us!!! damn! yah im goin wiht a whole new setup! t3/to4e !!!
so will it work?
TTT
Old Oct 19, 2002 | 04:38 AM
rjardy's Avatar
1. Yes the manifold will work.
2. They will more than likely leak fuel, go get new o-rings.
3. Buy a bolt that will fit the threads of the AN fitting in the pan, and plug it up like that.
Rob
Old Oct 19, 2002 | 04:09 PM
boostinb18's Avatar
Default Re: Pullin off turbo.....NEED SOME HELP! (rjardy)
cool! the problem is the oil pn fittig is not a threaded fitting its a spout....... i just slide the oil line over it with a snail clamp..... what should i do about that?
thanks!
Old Oct 19, 2002 | 04:14 PM
mntdewred's Avatar
thanks!
take the pan off and plug the spout with some welding. i can picture exactly what yours looks like and welding would be the only way i could think of. won't take much, just a dab. plug both sides, inside the pan and out.
hopefully that helps
Old Oct 19, 2002 | 06:41 PM
sporkcrx's Avatar
Default Re: Pullin off turbo.....NEED SOME HELP! (mntdewred)
hey geoff...when i took my turbo off b/c of the bad seals, to plug up the oil pan tap i just ran the same size hose about half a foot away from the pan (it's sittin on the cross member, that way it wont get caught on anything or scrape) but it's a hose sitting on the cross member, plugged w/ a long bolt...and I cut off the threads, so that the bolt is basically a metal rod (you know how the long ones are like that, the thread is on the bottom), then just tightened it up w/ a hose clamp. my bolt is a lil too small so it leaks very little if in high rpms...but w/ the right bolt it shouldn't leak. you can also put some good ol' hondabond around the bolt head! that'll stop it if it leaks at all. -sean
Old Oct 19, 2002 | 11:47 PM
boostinb18's Avatar
Default Re: Pullin off turbo.....NEED SOME HELP! (spoon2)
im not going to weld it since im going to boost again just not until i get my new stuff.
thanks sean......... i bought some thick vacuum caps, same size as my return spout and i want to put that on with some gasket sealer and a hose clamp..... it should hold up!!
and the GSR manifold isnt too short???
and i am running 1 heat range colder plugs........will this effect my performance?? should i buy some new ones...and what should i get.
Old Oct 20, 2002 | 01:06 AM
boostinb18's Avatar
bump!
Old Oct 20, 2002 | 01:07 PM
boostinb18's Avatar
anyone else?????
Old Oct 20, 2002 | 06:54 PM
shadowdawn's Avatar
Well got my DP off and oil return line off.... but the GOD DAMN coolant lines aren't budging... I think I'm just gonna cut those bitches off.... only other thing I hope isen't a real pain is the feed line.... anyway gotta get back to work, ah the sweet smell of oil and coolant
Old Oct 20, 2002 | 08:55 PM
boostinb18's Avatar
thats sucks about the coolant........ keep us up to date on the uninstall, and what did you do about the oil return line and stuff??
Old Oct 20, 2002 | 09:45 PM
sporkcrx's Avatar
I have a tee on the firewall w/ 1/8npt females on all sides...i just went to a hydralic store and they gave me a 1/8 plug, works fine and didn't cost a dime.
Old Oct 20, 2002 | 10:40 PM
shadowdawn's Avatar
Remeber I'm only taking the turbo off and getting it rebuilt I'm not going back to stock or anything.... anyway I FINALLY got the turbo+mani out and just cut the coolant lines, theres enough left of them to hook back up to the barb fittings...
The feed line was a bitch but got it off after some time. The WORST part was the bolts from the turbo to mani... 1 in specific was 1/8" away from the god damn feed fitting.... so after dremeling a 17mm wrench we manage to finally complete the turbo removal, its 2:42am I smell like garage floor, coolant, and oil.... and my garage has pieces of my car EVERYWHERE.... **** it all I wrapped up the turbo, ready to ship tomorrow I'm taking a shower, eating, shitting, smoking a cig and going the **** to bed......
Old Oct 20, 2002 | 10:43 PM
boostinb18's Avatar
glad you got it off! yah mine is going to go back on too but it will be a while till i go back to boost!
Old Oct 21, 2002 | 03:40 AM
boostinb18's Avatar
bump
Old Oct 21, 2002 | 04:06 PM
boostinb18's Avatar
b u m p............ i need to know!
Hoe Hopper
Dec 5, 2009 10:35 AM
chb93
Aug 1, 2009 08:15 AM
1994delsolLS
Nov 15, 2008 07:12 AM
2wheelhunter
Jul 9, 2006 07:24 PM
preludef22a
Oct 18, 2004 01:38 AM
