newb needs help with turbo question.
Old Oct 18, 2002 | 05:28 PM
smooz EK's Avatar
Default newb needs help with turbo question.
what are the differences between the TD04, T3/T4, T3/T04E, etc, etc...??? what's the differences in the brands like Revhard kits, Greddy kits, Fmax, etc..?? are some better then others?
i have a EK hatch and am planning to turbo my stock SOHC motor - is there a specific one i should get?
thanks for the help.
Old Oct 18, 2002 | 08:38 PM
willyboyK20's Avatar
Default Re: newb needs help with turbo question. (smooz EK)
i will try to answer but your questions are a bit vague. I never though I say this but the search method really works.
The td04-15g for the sohc is good for the street. quick spool up time
The rest that u mentioned are generally good for top end and more power. They don't take that long to spool, but when they do watch out.
It all depends on what u want for the motor. Do a search on those kits u mentioned and u will find alot of info from guys who have already gone down that route.
Old Oct 18, 2002 | 08:59 PM
Drew Peacock's Avatar
Default Re: newb needs help with turbo question. (willyboyD16)
Good answer above if you are staying stock I'd reccomend the greddy if you want big power "forged internals" rev hard etc . State your goals.
Old Oct 19, 2002 | 12:36 AM
smooz EK's Avatar
Default Re: newb needs help with turbo question. (turbozxi)
my goals are to run around low 14's. i'm also going to build my motor so i can boost around 12 psi.
i did a search and it seems that most people have the T3/T4.
MonkeyParty
May 15, 2014 10:19 PM
tweekerz
Jul 21, 2005 01:21 PM
nochance
Jul 29, 2003 07:50 AM
MiniMeonBoost
Mar 26, 2003 01:06 PM
yusoslo
Nov 15, 2002 10:23 AM
