cranking engine by hand
Old Oct 18, 2002 | 09:24 PM
Lei Siew Long's Avatar
Default cranking engine by hand
i had my engine built recently. i drove it for a few days and it has been sitting for about two and a half weeks.
no matter how hard i try, i can't crank the engine by hand. i'm doing this to circulate the oil through the engine and turbo
is this normal?
Old Oct 18, 2002 | 09:47 PM
ninesecrx's Avatar
Default Re: cranking engine by hand (boostedeg6)
you should be able to turn it over by hand. Take spark plugs out, see if its easier.
Old Oct 18, 2002 | 09:55 PM
Default Re: cranking engine by hand (ninesecrx)
thanks for the quick reply.
yeah, the plugs have been pulled out and i did notice that the timing belt has lost some tension on the side facing the front of the car.
any other suggestions.
Old Oct 19, 2002 | 12:38 AM
sparkz's Avatar
You can also pull the ECU fuse and have the starter crank it over a few times. I just rebuilt my bottom too and noticed it was pretty hard to turn by hand the first few times as well. I assumed it was because my clearances on the mains and rods were on the tighter side of the honda spec.
rixceu
Jan 6, 2017 01:27 PM
trustbuddy
Jan 14, 2006 08:27 PM
Hyb
Mar 23, 2005 07:04 PM
DevLishPlaya
Jul 19, 2003 11:01 AM
