Help...I have oil leaking somewhere from the top of my turbo
I know how to do everything on my car. The only problem I have is with the turbo itself. I dont really understand much about it. It seems like oil is leaking from the top where the oil feed goes in. It doesnt look like the feed line or fitting is leaking..could it be the seals on the turbo or what? It not leaking alot but enough to **** me off.
Re: Help...I have oil leaking somewhere from the top of my turbo (Farnsrocket)
Did you use teflon tape on the adapter fitting that goes into the turbo?
Re: Help...I have oil leaking somewhere from the top of my turbo (Elite Hatch)
hey mike its teen wolf if ur using that oil feed line from inline it did the same damn thing to me and then the ****** broke and i was screwed cause i was running my car without oil but if i were u id take the oil line off and check to see if its getting a smooth flow because if it gets hot the rubber hosing will get all kinked up and **** but IM me i mioghtt know a few other things
Re: Help...I have oil leaking somewhere from the top of my turbo (solswap)
Good looking out man...Its not the inline kit though its a Autometer kit
New User
My braided stainless fitting that went into the turbo actually made mine leak for a little while. I went to a local hot rod shop and bought a 90 degree end braided stainless Goodridge brake line from them for some old skool car, and it se3aled up perfectly. Just taking the turbo off, on and off and on caused the seal to go out in the stainless line, I suppose. No problems since, I just have a pretty long oil line now
