what turbo can should i go with??
what turbo cam should i go with??
i have a 1995 integra gsr with a stock bottom end for now with a drag kit running 10 psi of boost, i have the JG intake mani and about to order the throtal body and i am tring to find out what size i should go with that.
i am looking for a good turbo cam what brand should i go with??
[Modified by turbogsrb18c1, 10:12 PM 10/19/2002]
Re: what turbo cam should i go with?? (turbogsrb18c1)
I wouldn't waste your money on cams, save it to build the bottom end. The stock cams are good and running 5psi more boost will get you more power than any cam could ever give
You could maybe go with a 65-70mm throttle body (just get one off a Mustange 5.0?) but, I guess it depends on the manifold.
i would get a 70 mm but if you have the jg intake manifold i think thats a 65mm opening so you would have to bore that as well. or just get a 65mm.
lamboextreme
20
01-07-2007 06:17 PM
