N2O Problem
Old Oct 17, 2002 | 11:21 AM
816d16's Avatar
GDD's DJ EX-M0D
Community Builder
Community Influencer
Default N2O Problem
Setup - 94 ex coupe, d16z6, i/h/e, zex plugs, & NX efi stage 1 50 shot
Temp - 50's and 60's outside
Problem - I just got my bottle filled. When I spray it feels like a normal run for maybe a second, then the car bogs, and I can feel the front end dip down. What could be the problem? Detonation, too much fuel, clogged lines, no pressure?
Oh, and everything seems to be running fine when I'm accelerating and not spraying.
[Modified by 816d16, 8:21 PM 10/17/2002]
Old Oct 17, 2002 | 11:25 AM
TGUNNER's Avatar
Default Re: N2O Problem (816d16)
Is your bottle pressure over 900psi?? It sould be around that area..
Old Oct 17, 2002 | 11:35 AM
816d16's Avatar
GDD's DJ EX-M0D
Community Builder
Default Re: N2O Problem (TGUNNER)
Haven't got my gauge hooked up yet, waiting on a "y" line. Do you think that's what it is though? Would it be real low around 50 degrees outside and cause my car to do that?
Old Oct 17, 2002 | 12:27 PM
PM-Performance's Avatar
y ? just put it right on the bottle.
get a warmer, 9/10 its prob that
Old Oct 17, 2002 | 12:28 PM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
i'm by no means an n2o genius but i do know about chemistry and pressure related to temperature. It sounds like the bottle pressure is too low but has enough to get the first bit of n2o in your engine. Then as you keep spraying the temperature of the bottle drops (thats just what happens to all sorts of things like propane bottles, and CO2 paintball or bb gun canisters) and so does the pressure. The pressure may be dropping past the point to where its effective. Get your pressure gauge installed and check that out.
Old Oct 17, 2002 | 12:33 PM
816d16's Avatar
GDD's DJ EX-M0D
Community Builder
Default Re: N2O Problem (PreIudeSI)
Thanks guys.
Old Oct 17, 2002 | 01:04 PM
madman604's Avatar
i suggest getting a "purge kit" this removes the gaseos nitrous from the lines and makes sure the lines are filled with liquid nitrous. keeps your times consistant presuming you're an OK driver
Lamafia ck
Aug 2, 2007 06:23 PM
CarAudiophile
Apr 15, 2005 01:21 PM
JTCdudeman
Nov 12, 2003 05:16 PM
tek_civic
Dec 16, 2002 03:36 PM
Soled Out
Oct 11, 2002 06:17 AM
