quick headgasket and ARP head stud question!!!!
Old Oct 19, 2002 | 08:08 AM
TheSwift1's Avatar
Default quick headgasket and ARP head stud question!!!!
I've got a B18C block with a B16 head....which head gasket and head studs should i use? I'll be using an OEM headgasket...someone told me to use the Tpye-R headgasket, as the Type-R engine is essentially a B18C block with a B16 head...is this correct?
and as far as the ARP head studs, should I get the ones for a Type-R also? i remember reading something about not all studs fitting exactly otherwise....thanx guys...
Old Oct 19, 2002 | 09:00 AM
Brian_92GSR's Avatar
New User
Default Re: quick headgasket and ARP head stud question!!!! (TheSwift1)
The b18c1 headstuds won't work with the type-r head. I don't remember seeing an application for the b18c5, but I know they make them for the b16a. Those will work.
Old Oct 19, 2002 | 09:01 AM
BoOsTeD_eK's Avatar
I say go with the gasket that matches the head. Eventhough I have a feeling that all vtec gaskets are the same, but I am not 100% sure on that...as far as the studs then yeah vtec one will do.
Old Oct 19, 2002 | 09:11 AM
1.8T_EG's Avatar
Default Re: quick headgasket and ARP head stud question!!!! (BoOsTeD_eK)
... i have read that the b16 and b18c1 head gaskets are the same also... can anyone else confirm this?... as for head studs, i'd like to know too...
Old Oct 19, 2002 | 09:13 AM
TheSwift1's Avatar
so then i should be OK goin with the Type-R applications?
i mean cuz a Type-R has the exact head as a B16, with the exception of some mild porting and better cams...and the block is basically a B18C (GS-R block)...which is my setup...
Old Oct 19, 2002 | 09:14 AM
TurboDANDEE's Avatar
Default Re: quick headgasket and ARP head stud question!!!! (1.8T_EG)
all vtec studs (aftermarket) and headgaskets are all the same. If you're going OEM studs, B16 is a little shorter, if used with a b18, its too short and it will strip.
[Modified by TurboDANDEE, 10:16 AM 10/19/2002]
Old Oct 19, 2002 | 09:50 AM
internet ay's Avatar
Default Re: quick headgasket and ARP head stud question!!!! (TurboDANDEE)
i double that thought i have a ls vtec with b18a block and b16 head and i used the b18c1 head studs. so i dont think the b16 ones will work, i think they will be to short
Old Oct 19, 2002 | 04:23 PM
New User
Default Re: quick headgasket and ARP head stud question!!!! (internet ay)
With a PR3 head (b16a, b17a, b18c5) you want to use the b16a headstuds. The b18c studs will work, but they are too long, and it's very likely the nut will run out of thread before it's all the way in. I've used both the b18c and b16a studs with my PR3 head, don't take the chance.
Old Oct 19, 2002 | 08:48 PM
TheSwift1's Avatar
soo...uhh....Type-R studs wouldn't work?
Old Oct 19, 2002 | 10:28 PM
New User
Yes, type-r studs should be identical to b16a studs. I've just never seen type-r studs listed in arp's catalog.
Old Oct 19, 2002 | 10:36 PM
Default Re: quick headgasket and ARP head stud question!!!! (Brian_92GSR)
So you're saying that with the b18c5, you would use the b16 head studs? Why in the hell would you do that??
No it's not too long and the "nut" will not run out of threads. What "nut" are you talking about? the B16 studs doesnt have enough threads to catch the block when used with a B18 blocks.
i think you need more experience with this.
The way you choose the head studs is go with whatever block you have, same with the head gaskets. If you have a B18c block, use a B18c studs and headgaskets because if you use a B16 studs, its too short and it will strip because the B16 block is shorter than B18c and it doesnt have long enough threads to catch the block. If u have a B18b or Ls/Vtec, you would use a B18b studs and Ls headgasket, not vtec headgasket.
Old Oct 20, 2002 | 09:50 AM
New User
I have expierence within the last week of the b18c1 and b16a head studs. The b18c1 head is larger than the PR3. Using the b18c1 studs with the PR3 head will result in the nut reaching the end of the thread (what do you mean "what nut", last I check a headstud only uses one nut). Sorry I can't make this any more simple. This will be my last post on the subject. I really don't care what yoy do, I'm just relaying the information I found and experience I went through putting my last motor together.
Edit - I just check ARP's catalog and they don't even have a listing for the b18c5.
[Modified by Brian_92GSR, 1:54 PM 10/20/2002]
Old Oct 20, 2002 | 01:00 PM
qwkteg125's Avatar
i used b18c studs on my ls-vtec, b18a block with 2000 type-r head. didn't need to modify anything & had plenty of thread to torque the head down.
Old Oct 20, 2002 | 02:18 PM
rondigs's Avatar
Default Re: quick headgasket and ARP head stud question!!!! (qwkteg125)
Anyone that is doing the LS/VTEC (B18a/b block w/vtec head) conversion disregard what turbo dandee mentioned about using B18b head studs. B18c head studs are the studs of choice. Just don't want people to be misinformed....
Old Oct 20, 2002 | 03:27 PM
turbotypeR@SPEC's Avatar
25 Year Member
Default Re: quick headgasket and ARP head stud question!!!! (rondigs)
b18c1 head studs are the correct ones for the R.i have had them on mine for over a year now.
Old Oct 23, 2002 | 07:49 PM
TheSwift1's Avatar
thanx for the responses guys... now i'm 85% sure to go with B18C studs..
Old Oct 23, 2002 | 07:58 PM
tony1's Avatar
go with the b18c... 95% now
projectef
20
Mar 5, 2022 08:47 PM
fusion645
Mar 8, 2010 05:49 PM
armrslr
Jun 23, 2003 11:45 PM
RICE POLICE SIP
May 3, 2003 11:10 PM
riceboyEFsi
Dec 8, 2002 03:43 PM
