Want to know what type of turbo to put in your car?
Old 10-17-2002, 10:54 AM
mrblur's Avatar
Default Want to know what type of turbo to put in your car?
There might be more types of turbos, but I got this from an article in sport car magazine. IT could probably have been easier to scan, but dont have a scanner. So I retyped it. It took about 6 hours messing around the tables to line up. Well here it goes. any input or revisions appreciated so dont flame. Hope this helps.
First table is for quick boost and dies out quick, starts building boost at 1500rpm to 2000rpm and working hard by 2500 to 3500 (good for 6-16psi).
Junkyard turbos are probably best for lower boost nor more than 10psi on bigger engines and 14psi on smaller engines. Also junkyard turbos coming from automatics transmission typically have smaller exhaust housings for quicker spool but less top-end power.
1500cc to 1800cc Engine displacement
Custom built turbos Compressor wheel Compressor housing Turbine Wheel Turbine housing
Garrett T28 60 trim T3 .48 a/r T3 68 trim T25 .64 to .86 a/r T25
Off the shelf turbos
HKS GT230 dual ball bearing recommend switching .86 a/r HKS housing JWT Sport 600
JWT Sport 650 XS Engineering TO4E-46T
XS Engineering XB34 ball bearing
Junkyard Dogs
Turbo Type Donor Car
Garrett T25/T2 60-96 Nissan 300ZXTT manual trans
Garrett T25 2nd gen eclipse
Garrett T25 JDM SR20DET BLUEBIRD
Garrett T28 JDM SR20DET Gti-R
Garrett T25 JDM PS13 Silvia
Garrett T28 (ball bearing center section) JDM S14/S15 Silvia
Mitsubishi 14B Mitsu Eclipse 1st gen 5-speed
Mitsubishi 13G Mitsu Eclipse 1st gen A/T
Mitsubishi TC04-09B Mitsubishi Mirage Turbo
1800cc TO 2200cc Engine Displacement
Garrett T28 50 to 60 trim T3 .48 a/r T3 68 trim T25 .86 a/r T25
Garrett T28 68 trim T3 .60 a/r T04B 79 trim T25 .86 a/r T25
Garrett T3 50 to 60-trim T3 .48 a/r T3 72 trim T3 .63 to .82 a/r T3
Note:these combinations are available with sleeve bearings from most Garret distributors, single ball bearing from Turbonetics, or dual ball bearing from innovative turbosystems.
Off-the-shelf turbos
HKS GT2530 with a .86 a/r exhaust housing, dual ball bearing center section.
HKS GT2835 with a .86 a/r exhaust housing, dual ball bearing center section.
JWT Sport 650
IHI AX53B70 Ballbearing center section, abradeable seal compressor housing internal wastegate.
FPBIG28.Forced performance hotted up bolt on DSM turbo.
Mitsubishi TD05H-16G
XS Engineering T04E-50T
XS Engineering XB39 ball bearing center section
Junkyard Dogs
Garrett T25 2nd gen eclipse take off turbo
Garrett T25 JDM SR20DET Bluebird
Mitsubishi 14B Mitsu eclipse 1st gen 5-speed
Mitsubishi TC05-12A Mitsu Cordia/Tredia/Galant
Mitsubishi TTC05-10A Mitsubishi D50 pick up
Garrett T3 .48-.63 exhaust housing Ford: Thunderbird turbo coupe/Mercury cougar XR/7, Mustang SVO/Merkur XR4Ti
Garrett T3 SAAB 900 Turbo
Mitsubishi TE04H-13C, Garrett T3 Chrysler 2.2 liter, various Shelbys, Omnis, etc.
Toyota CT26 Toyota MR2
2200cc to 2600cc Engine Displacement
Garrett T3 60 trim T3 .48 a/r T3 72 trim T3 .63 to .82 a/r T3
Garrett T3 62 trim T3 .60 a/r T04B 72 trim T3 .82 a/r T3
IHI AX53B70 Ball bearing center section, abradeable seal compressor housing internal wastegate Mitsubishi TD05H-16G
HKS GT2835 with a .86 a/r exhaust housing, dual ball bearing center section XS Engineering T04X-56T
XS Engineering XB45 ball bearing center section
JWT Sport 650
Junkyard Dog
Garret T3 .48-.63 exhaust housing Ford: Thunderbird turbo coupe/Mercury cougar XR/7, Mustang SVO/Merkur XR4Ti
Garrett T3 Saab 900 Turbo
Mitsubishi TD05-12 Mitsubishi Starion
Mitsubishi TE04H-13C, Garrett T3 Chrysler 2.2 liter,various Shelbys, Omnis, etc.
Maximum street performance
these turbos have boost at 2500 rpm working hard at 3500 to 4500rpm. remember the ball bearing center section have boost 400-600 less lag.
1500cc to 1800cc Engine Displacement
Custom Built Turbos Compressor Wheel Compressor Housing Turbine Wheel Turbine Housing
Garrett T28 62 trim T3 .60 a/r T04B 79 trim T25 .86 a/r T25
Garrett T3 50-60 trim T3 .48-.60 a/r T3 72 trim T3 .82 a/r T3
Garrett T3/T4 46 trim T04E .50 a/r T04E 76 trim T31 .63 a/r T3
(this works well for high reving smaller engines like a Honda B16A)
Off The Shelf Turbos
HKS GT2535 with a .86 a/r exhaust housing, dual ball bearing center section
JWT Sport 650
IHI AX53B60 ball bearing center section, abradeable seal compressor housing internal wastegate
XS Engineering T04E-54T
XS Engineering XB46R ball bearing center section
Junkyard Dogs
Garrett T25 JDM SR20DET GTI-R
Garrett T3 .48-.63 exhaust housing Ford thunderbird turbo coupe/mercury cougar XR-7 mustang SVO/Merkur XR4Ti
Garrett T3 SAAB 900 turbo
Mitsubishi TD05-12A Mitsubishi Starion
1800cc to 2200cc Engine Displacement
Garrett T3/T4 hybird 50 trim T04E .50 a/r T04E 76 trim T31 .82 a/r T3
Note: these combinations are available with sleeve bearings from most garrett distributor, single ball bearing from turbonetics or dual ball bearing from innovative turbosystems.
Off the shelf Turbos
HKS GT3037 with a .70 a/r exhaust housing, dual ball bearing center section.
Force performance green turbo
IHI AX53B70 ball bearing center section, abradeable seal compressor housing internal wastegate.
Mitsubishi TD05H-Big 16G
XS Engineering XB47R ball bearing center section
Mitsubishi TD06 20G
Garrett T3/T4 Hybird 60 trim T04E .60 a/r T04E 76 trim T350 .82 a/r T3
Note: these combinations are available with sleeve bearings from most garrett distributors single ball bearing from turbonetics, or dual ball bearing from innovative turbosystems.
Off The shelf turbos
IHI RX-6 TCW10 ball bearing center section
XS Engineering T04S
XS Engineering XB55-1 ball bearing center section.
It did not come out like I hoped it would email if you want it with the nice table.
I have race table, but I am not done with it going to awhile, Iam kind of tired of typing and messing around with the table.
Lates, MrBLuR, Hope it helps and answer any questions, by the way Igetting the starion turbo TD05-12A(50 bucks can beat that)
Old 10-17-2002, 11:04 AM
mrblur's Avatar
Default Re: Want to know what type of turbo to put in your car? (mrblur)
reading my own post its hard to understand it if you want it with tables email me.
Lates, MRBLuR
Old 10-18-2002, 10:57 PM
mrblur's Avatar
Nobody think is useful
Lates, MrBLuR
Del_Slowest
11-11-2004 08:25 PM
crxsir23
07-21-2004 06:23 PM
DB2
06-15-2003 07:53 AM
bluedelsol
06-14-2003 11:37 AM
*Boostwerks*
09-20-2002 12:12 AM
Quick Reply: Want to know what type of turbo to put in your car?
