... help!!!... blown head gasket!!!...
... i need a cometic head gasket and arp head studs!!!... whos got the best deal?... (hondasavers hook me up!)...
... what else do i need to do?!?... i know i have to have a machine shop inspect everything and maybe mill the head if it is warped... then i need a thicker head gasket (which one?)... anything else i am missing?... lemme know... thanks...
i have both in stock if you need both of them...
also, while i have the head off should i just build the motor?... lets say i have a $2000 budget (hypothetical(sp?)) for the winter... what should i do?... sleeve? pistons? rods? cams?... from ur sig, it looks like you know your shiet... lemme know... thanks...
i would build if you got hte time. about 2000 cna get it done easily.
$2k was totally hypthetical... very tempting... but it would not be all up front... i would have to live frugal all winter and save up month by month... very tempting though
...so how much for just the head gasket and the head studs?... how about everything else?... can you gimme prices?... (pm me if they are too low to post)...
thanks viren!!!
((if i lived anywhere in texas, i would definitely have you build my motor this winter!!!))
For starters if you do decide to build your motor.....get it sleeved maybe overbore to .83 mil get some stronger rods and forged pistons, that way you'll be able to boost more, depending on what kind of management system you run.
$90 shipped
Vtec04
Engine Machining & Assembly
11
Oct 31, 2017 09:26 AM
Crackerballer
Dec 29, 2003 04:58 PM
