questions for guys with built motors...and transmissions with lsd
what is normal map voltage supposed to be at?
(1)from the aem we were reading 1.1v is this right?
(2)my kaaz pops! during turns any clue why???? do i need to break it in better or something?
any last min run downs before going to dyno and boosting to 20 psi?
thanks
thanks
Re: questions for guys with built motors...and transmissions with lsd (wicx)
hey wic what tranny fluid are you using.. the kazz like there own fluid the best .
Re: questions for guys with built motors...and transmissions with lsd (dustin)
you may have not shimmed the lsd correctly, there is a little nipple thats sticks up inside the tranny that the gear will rub on if its shimmed too low.
Re: questions for guys with built motors...and transmissions with lsd (b18bturbo)
i'm using honda tranny fluid. arent honda trannys(synchros) sensitive to particular fluids?
