Greddy Turbo Kit w/ ZC/D16A6 Motor
What modifications have to be done in order for this kit to work w/ the D16A6 (88 CRX Si)? What are the wiring issues that must be addressed?
*Used search function, couldn't come up with anything*
Re: Greddy Turbo Kit w/ ZC/D16A6 Motor (DRFlickner)
you just have to route the intercooler piping differently and you cant use the blue box fuel controller that comes with the kit. no wiring really, you might want to use some check valves in the map sensor vac. line.
Re: Greddy Turbo Kit w/ ZC/D16A6 Motor (CrX1988Zc)
I'd probably be safer using a missing link bypass than check valves, right?
Is it difficult to route the intercooler piping, or does custom piping need to be made? Do the injectors that come with the kit work in the CRX w/ no problems?
Thanks!
Thanks!
yea a missing link is much better than check valves.
the intercooler piping isnt difficult you'll probably have to get some different silicon connectors and cut the piping so you can angle it etc.
injectors dont come with the kit. stock injectors are fine until about 6-7psi.
Kelly.
03-13-2004 06:19 PM
SpoolnG2
05-28-2003 10:09 PM
PM-Performance
11-05-2002 10:04 AM
