Piston matching question, help ASAP
Old Jan 22, 2003 | 12:05 AM
austrian type-R's Avatar
Default Piston matching question, help ASAP
I have here a set of 9:1 JE pro Series, stock bore for B18C5. There is a guy who needs pistons in my area, but he has a B16A2 engine. I know the rod length is different, but my question is......how much cr will I get out with the piston, if it match the rod eye and will not hit the head........he runs a JRSC with 0.7 Bar.
So, I want to put in B18C5 pistons into B16CA2 engine, is that possible?!
Help me out quick please.
Old Jan 22, 2003 | 01:41 AM
BudaKai's Avatar
Default Re: Piston matching question, help ASAP (austrian type-R)
We just went over this in another post. You're going to lose compression with those. The B18 pistons have a smaller dome or a larger dish than the B16 equivalent SCR pistons.
Old Jan 22, 2003 | 01:59 AM
Default Re: Piston matching question, help ASAP (tzsir)
thx, but what cr do I went out, less than 9:1 is fine, I can always mill the head. Some more info or the link to the post would be fine...the searching machine found nothing.
Old Jan 22, 2003 | 02:59 AM
BudaKai's Avatar
Umm I'm confused on what you're asking, but I'll try to answer. Your SCR should be around 8.5-8.7:1. Never mill the head it's a bad practice to get into.
edit: here's the link https://honda-tech.com/zerothread?id=392454
[Modified by tzsir, 6:00 AM 1/22/2003]
Old Jan 22, 2003 | 03:13 AM
why should I not mill the head? The quench area is not the best on Hondas, for whatever reason, so milling the head a bit to get out cr 9:1 should be okay IMO.
Perhaps someone else can confirm me, that my JE 9:1 B18C6 piston will fit into B16A2 and getting out 8.5:1 cr. I have to be 100% sure
[Modified by austrian type-R, 1:15 PM 1/22/2003]
Old Jan 22, 2003 | 05:25 AM
boostaholic's Avatar
There is about a -.9 difference in compression ratio using a b18c1/c5 piston in a b16a block. So figure 9.0:1 cr b18c5 pistons will yield 8.1:1 cr in a b16a block, the heads use the same combustion chamber volume so that won't matter.
[Modified by boostaholic, 2:26 PM 1/22/2003]
ekftw
10
Feb 19, 2010 01:16 PM
Figgy1682
Aug 1, 2007 09:55 PM
abnaasefmb
Jul 10, 2006 11:22 AM
austrian type-R
Apr 23, 2003 09:52 AM
BLKCRX
Apr 3, 2002 06:04 PM
