d16y7 crank and d16y8 crank
Old 01-22-2003, 03:09 AM
98civicEX's Avatar
Default d16y7 crank and d16y8 crank
does anyone know if there's a difference between these 2 cranks?
Old 01-22-2003, 05:10 AM
TurbodCX's Avatar
Default Re: d16y7 crank and d16y8 crank (98civicEX)
i think the mains are different sized... i know the rods are the same.. i am just not real sure about the mains.. i dont think the Y7 uses a main girdle like the Y8...
if you have both of the cranks,just get both of them miked (sp?) and that will tell you the difference in them...
Brian
Old 01-22-2003, 07:56 AM
boosted hybrid's Avatar
Default Re: d16y7 crank and d16y8 crank (TurbodCX)
I believe he is right. The Y8 blocks use the girdle and the Y7 cranks do not. The rod length is the same, i have personally looked at the rod sets next to each other. You may want to find out the stroke on each of those engines to double check.
Old 01-26-2003, 11:32 AM
98civicEX's Avatar
Default Re: d16y7 crank and d16y8 crank (boosted hybrid)
lined them up, they look identical.
Old 01-26-2003, 01:57 PM
Smashback's Avatar
If you look up part numbers for aftermarket pistons I believe they are the same. Other than the girdle and the oil pan, they seem to be indentical. I don't know about the mains, but I would think they would be the same.
Old 01-26-2003, 02:01 PM
Sonny's Avatar
The parts fiche at hondaautomotiveparts.com shows that the D16Y7 and D16Y8 both use a main cap girdle.
Sonny
Old 01-26-2003, 04:04 PM
Default Re: d16y7 crank and d16y8 crank (Sonny)
Strange, when my friend and i stripped down his y7 it didnt have a girdle. I might be mistaking the y7 for another d-series engine though. I am not completely up to par on d knowledge.
Old 01-26-2003, 05:34 PM
Smashback's Avatar
Don't feel bad...I've had my oil pan off 4 or 5 times on my Y7 and I can't remember either
Efjams24
06-17-2012 07:12 AM
1clean_ Ej
05-30-2007 12:54 PM
7808
02-09-2007 12:39 PM
hondalowlow
01-16-2006 10:54 AM
Dancing is Forbidden
09-07-2004 06:44 PM
Quick Reply: d16y7 crank and d16y8 crank
