ARP head studs for B16
Old Jan 21, 2003 | 02:27 AM
Herminator's Avatar
Default ARP head studs for B16
I tried to do a search and cant find anything on this subject. I read awhile back someone was using B18 ARP head studs and they work fine. Only problem is there a little longer just need some washers right?
If this is the case what washer size do I need?
How many washers do I need?
Old Jan 21, 2003 | 02:48 AM
ninesecrx's Avatar
Default Re: ARP head studs for B16 (Herminator)
you use gsr studs and they always come with washers otherwise the nuts would tear up the head.
Old Jan 21, 2003 | 03:09 AM
Herminator's Avatar
Default Re: ARP head studs for B16 (ninesecrx)
when you say they come with washers do they come with extra washers so I can fit the nut on my B16?
Old Jan 21, 2003 | 03:20 AM
MiraiZ's Avatar
they don't come with extra washers
Old Jan 21, 2003 | 05:58 AM
revhardsi's Avatar
Default Re: ARP head studs for B16 (MiraiZ)
+why in the world would u shim it with washers???? r u nuts! By the VW 1.8 head studs. They are the correct lenght for a b16.
Old Jan 21, 2003 | 06:18 AM
g2turbo's Avatar
Default Re: ARP head studs for B16 (revhardsi)
ive been running gsr ARP's for 12,000 miles now in my b16. straight out of the box i didnt modify them at all.
CHRIS
Old Jan 21, 2003 | 11:19 PM
Herminator's Avatar
can someone verify the validity of the VW 1.8 head studs fitting perfectly in the B16?
is validity a real word? hehe
Old Jan 22, 2003 | 04:28 AM
revhardsi's Avatar
trust me. call them up and see if they fixed the problem with that.
Old Jan 22, 2003 | 12:17 PM
turbosol's Avatar
My studs from ARP specifically stated that they were for a b16.
Old Jan 22, 2003 | 12:50 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: ARP head studs for B16 (turbosol)
I believe all b series v-tec motor stud kits are the same.
Old Jan 22, 2003 | 01:00 PM
BROOD's Avatar
Default Re: ARP head studs for B16 (MotorMatrix.com)
No they are not the same length....
[Modified by SLPR, 2:02 PM 1/22/2003]
Old Jan 22, 2003 | 01:13 PM
I am a bad person
Default Re: ARP head studs for B16 (SLPR)
all v-tec b series are the same part # arp 208-4303. that 1/8 inch wont make any difference. its a stud not a bolt. the both sink in the block and come up thru the head.
Old Jan 23, 2003 | 02:41 AM
Herminator's Avatar
Thanx for all the help guys. One more question. I was looking at the ARP web-site and was reading there Tech Tips : Head Stud Installation. It said to torque each stud nut three times to recomended values found in the general fasterner chart.
http://www.arp-bolts.com/pages/produ...s/how_tos.html
Is this safe to turque it that much or should I torque it to manufacturers spec?
Old Jan 23, 2003 | 04:09 AM
racerxadam's Avatar
they don't mean torque it to 3 x (torque) value. they mean go through the sequence 3 times.
00CivicSi5spd
Nov 16, 2015 06:57 PM
DC2.KILLA
Apr 16, 2011 06:43 AM
Mugen Dom
Feb 28, 2002 11:53 AM
