2k1 civic turbo fuel
hey i just got a turbo for my 2k1 civic.....i am running 5 psi with stock internals....i know i need to upgrade my fuel and but i was wondering if anyone can help me on what i need. i know i need a vortech fmu, bigger injectors, bigger fuel pump...and...i dontk now wat else. How long do you think i can last without any fuel mods?
Re: 2k1 civic turbo fuel (yellowsub)
Just stay outta boost.
As for on topic, for 5 psi on my ZC I didnt really do much extra to the fuel. I ran a Adjustable FPR set like 10psi higher static and I had no troubles, no signs of detonation and it actually ran rich. to be on the safe side for you maybe get the FMU and that should be ok, if you have the money the AFC Hack works well. A walbro FI intank pump works well if you want a new pump that can handle higher PSI. Injectors really arent necessary unless you can find some 310s for cheap, anything above that and a stock ecu wont be able to run them properly. AFC hack would run up to 450s fine though.
Re: 2k1 civic turbo fuel (reXem)
thanks rexem for your input......but you know that the 2k1 civic has a weird fuel system right? people have been telling me that you have to change the car into a fuel return system or something like that. i dont know i am a nub when it comes down to turbos. I will get the fmu this week and get that put in asap. the afc??....i dont know....because i know that **** cost like 300 dollars...after the custom turbo kit my wallet is hurting you knwo what i mean..hahahahahahhaaa...thanks again...and no thanks to the other post....
Re: 2k1 civic turbo fuel (2k1civicturbo)
I didnt know the new civics used a return less system, well then I dunno what to do...does it use a MAP sensor? if so the SMC would work for you do some searches on SMC
i think you are correct in saying that the newer civics dont have a fuel return line like the older civics have. I dont know what the fpr would look like or how exactly it works, or if it even has one, but id say get one if you can. 5 psi is really low boost though and you should not need much if anything, just dont get a boost controller.
Not sure about your cars fuel system, but I have an MSD inline and a 12:1 vortec FMU if you would like to buy them. i strongly recommend doing some more research on your car before you boost it. Get a Helms. Best $60 you'll ever spend. IM me if you want the fuel pump and the FMU.
Re: 2k1 civic turbo fuel (Tony Starks)
hey tony i e mailed you but just incase you dont get it i am interested in buyings your stuff. would it fit my car though? if it does i am interested. e mail me at roylee0484@yahoo.com thanks.
I am a bad person
the 2k1 civic has no return line and the pressure regulator is in the tank according to the manual. its the same as the rsx and new civc si.
so does anyone make an adjustable regulator? is it even possible?
are you sure? i know people that use the same fmu.
Haha I don't think Tony Stark is his real name...unless he's Iron Man damn I haven't seen him for like 15 years. He was one of my favorites!
