Oil Feed / Drain Kits
Old Jan 23, 2003 | 05:01 AM
spike's Avatar
Default Oil Feed / Drain Kits
My friend used the turbo-performance.com kit and it was like 70 bucks.. but the kid sucked. Everyone says to use the Earl fittings from some street rod site.. which I agree with but I did a totaling of all of the fittings and it was like 200 dollars! that's insane for an oil line kit. A couple of the fittings where swivel and they were like 30 alone. Is it asbolutely Necessary to get these swivel pieces? thanks! if anyone knows of a good kit or order list let me know please.
Old Jan 23, 2003 | 05:07 AM
silverEH2's Avatar
Default Re: Oil Feed / Drain Kits (spike)
are you sure it is 200.00, i paid like 100.00 for my drain/feed kit, i used earls fittings for the drain and a nos -3AN line for the feed line.
Old Jan 23, 2003 | 05:19 AM
spike's Avatar
Default Re: Oil Feed / Drain Kits (silverEH2)
do you possibly have a parts list from when you bought it? I found a list from amstreetrod in the archived section and no lie it was at like 140 when i said forget this.. and i was 3/4 of the way done the list..
Old Jan 24, 2003 | 11:00 AM
Jdm_Rice_Monster's Avatar
I was there slivereh2 paid like a bill for his setup, and its nice.
Old Jan 24, 2003 | 11:07 AM
spike's Avatar
do you have a parts list you can get me? also where did you get it from? thanks man!
Old Jan 24, 2003 | 11:08 AM
Pepboys, yeeeaaahhhhh. Na I think he got his stuff from summit.
Old Jan 24, 2003 | 11:11 AM
spike's Avatar
Default Re: Oil Feed / Drain Kits (JdmRiceMonster)
anyone got a parts list from summit? i've seen the amstreetrod list.. but that's the one that was real expensive for the kit.. thanks
Old Jan 24, 2003 | 11:12 AM
Smashback's Avatar
Braided lines are not cheap. Cheapest though is at racerpartswholesale.com.
Old Jan 24, 2003 | 11:21 AM
Default Re: Oil Feed / Drain Kits (Hatchblack)
Theres another place around called hosefast I believe, they are resonably priced.
Old Jan 24, 2003 | 12:21 PM
project dc2's Avatar
haha i paid a total of 50 bucks for mine ... go to amstreetrod.com
and get the speedflex hose, its SS braided, teflon, with straight swivel seal fittings on it . and its like 20$ !!!!
Old Jan 24, 2003 | 01:34 PM
silverEH2's Avatar
Default Re: Oil Feed / Drain Kits (project dc2)
i got my ish from vsv, they have a website it is vsvperformance.com
Old Jan 24, 2003 | 11:02 PM
spike's Avatar
Old Jan 24, 2003 | 11:23 PM
CzanSOHC's Avatar
Info provided by Fleminco-T:
Oil Return Parts list
Oil Drain Flange 1/2"
1/2" to -10AN adapter [981610erl]
2 of 45 deg or straight -10AN swivel seal hose ends [804610erl or 800110erl]
1' to 1.5' of -10 Performo flex lines [400100erl]
Steel -10 weld on bung [967110erl]
Oil feed line part list
1- male 1/8" BSPT to female 1/8" NPT adapter (aluminum)
1- 1/8" NPT Brass Tee adapter with one male out and two females.
1- 3.5' of -3AN lines with hose ends attach
1- straight 1/8" NPT to -3AN adapter
1- 90 deg 1/8" NPT to -3AN adapter
Old Jan 26, 2003 | 09:50 PM
J2turbo21's Avatar
Default Re: Oil Feed / Drain Kits (CzanSOHC)
Do all turbos take the same size feed kit?
Old Mar 12, 2003 | 09:39 AM
2000GSRT's Avatar
Default Re: Oil Feed / Drain Kits (J2turbo21)
Here is a good diagram of what you will need if you want to hook up an oil pressure guage too
Old Mar 12, 2003 | 01:08 PM
hollaback6's Avatar
look into gettin one from jgs. the site is http://www.jgstools.com/turbo/
Old Mar 12, 2003 | 01:17 PM
B18EG6's Avatar
Default Re: Oil Feed / Drain Kits (hollaback6)
Here is my writeup, very cheap and very nice feed line.
https://honda-tech.com/zerothread?id=432769
Old Mar 12, 2003 | 01:31 PM
RyanAutry's Avatar
Default Re: Oil Feed / Drain Kits (B18EG6)
Please check this thread.
Old Mar 12, 2003 | 01:39 PM
TurboedGSR's Avatar
Default Re: Oil Feed / Drain Kits (RyanAutry)
delete "orig.jpg" at the end...
Old Mar 13, 2003 | 05:14 AM
Flamenco-T's Avatar
no, 4 bolts take different feed lien than 5 bolts, DSM and Mitsu turbo are different as well..
stan
Old Mar 13, 2003 | 06:59 AM
MugenGTR's Avatar
Default Re: Oil Feed / Drain Kits (TurboedGSR)
nice diagram!
Old Mar 13, 2003 | 08:30 AM
PWRVTEC's Avatar
I get all of my fittings and stuff from a local Rubber company....
I use the Teflon bradied steel lines, and the fittings for it are 1/2 the price or more. I also get the high pressure clamps from them for super cheap...
Old Mar 13, 2003 | 10:19 AM
dustineck's Avatar
I pieced together my own fedd/drain kit and it only cost me about $70, with all earl's fitting and braided lines.
Old Mar 13, 2003 | 12:35 PM
maxpsi's Avatar
For what application or does it matter? I have a heater hose temporarily for my B16Drag civic. I want to replace it with Earl's, but don't know what all is needed?
Old Mar 13, 2003 | 12:58 PM
Flamenco-T's Avatar
Default Re: Oil Feed / Drain Kits (maxpsi)
the return will work on all T3 cartridge based turbo liek T3, T3/4e, b and etc
