DSM Injectors in B18 Tubro
T3/04B tubro set-up on a GSR, can i run the stock DSM injectors, without a FMU and missing link. What kind of set-up do i need in order to run the DSM injectors???
Re: DSM Injectors in B18 Tubro (Int3Gra147)
you need a resistor box and some sort of method to tame/controll the injectors....IE standalone, AFC hack. afc and missing link...etc...
Re: DSM Injectors in B18 Tubro (CzanSOHC)
According to this site http://www.thedropshop.tv/vafc.htm, all i need is the V-AFC, and a boost retard? Are the figures given on the site,on the settings on the V-AFC correct???
[Modified by Int3Gra147, 9:14 PM 1/22/2003]
If you don't mind sluggish throttle response, you can get by with just the afc and no ignition retard module. You just need to manually retard your timing.
