what kind of compression, how much boost, ets.....(b18b)
Old Jan 23, 2003 | 09:06 AM
DjFreeze's Avatar
Default what kind of compression, how much boost, ets.....(b18b)
hi, i got a b18b which im gonna rebuild for turbo.. what kind of compression should i run and how much boost, to be in the 12'-11's range? also someone told me to ask here about resleaving.. would it be necessary or could i do with just a block guard? also if you got some pics/spec's of you b18 civics that would be kool too.
thanks in advance.
Old Jan 23, 2003 | 09:16 AM
b18bturbo's Avatar
Default Re: what kind of compression, how much boost, ets.....(b18b) (DjFreeze)
the stock b18b is good to around 12 psi with out really much else. I would just get your block sleeved open deck darton with 81.5mm piston with 9.2:1 compression or so and run aroudn 15 psi with a good fuel system. that should net you in the 12s 11s pretty easy.
12psi stock block in light hatch i ran 11.8 car weight 2454lbs with stero 94 si
turbob16ef
10
Aug 28, 2005 05:18 PM
pcguy760
May 1, 2005 05:21 PM
DeadVet
Apr 26, 2005 11:51 AM
Rob!
Jul 19, 2004 06:42 PM
InfamousRS
Feb 22, 2002 10:40 AM
