LS (only) crower cam users (info needed)
Old Jan 22, 2003 | 04:39 PM
DRAGLS's Avatar
Default LS (only) crower cam users (info needed)
Modified by DRAGLS at 7:34 PM 1/5/2007
Old Jan 22, 2003 | 07:17 PM
Midwestrider's Avatar
Default Re: ls(DRAGLS)
I am curious on this too..
Old Jan 22, 2003 | 08:50 PM
CheezeFrog's Avatar
Default Crower Cams
I'm buying an LS motor that made 406hp at the wheels with Crower cams. I'm not sure what model they are though. I'm hoping to break 450+whp with good tuning. Ping me in 3 weeks.
Old Jan 22, 2003 | 09:39 PM
boostaholic's Avatar
Default Re: Crower Cams (CheezeFrog)
Would this happen to be Elvis' LS motor?
Old Jan 23, 2003 | 02:17 AM
pissedoffsol's Avatar
25 Year Member
Default Re: Crower Cams (boostaholic)
i have the 62402T from crower....
bad *** cams
Old Jan 23, 2003 | 10:21 PM
CheezeFrog's Avatar
Yes. I would like to break 500whp after st00pid tunes it.
Old Jan 23, 2003 | 10:48 PM
Can you see what model the are?
Thanks..
BTW how is you build up coming?
Old Jan 25, 2003 | 12:57 PM
yellaboi's Avatar
Default Re: Crower Cams (Midwestrider)
I have found that the 402 or 402T are best for boost the 403's have too much duration.
Old Jan 25, 2003 | 06:19 PM
Speed PHreak's Avatar
Default Re: Crower Cams (delvtecsol)
bad *** cams
I have something similar, a bit different tho. For LS engines something with lots of lift and not so much duration is killer. Somebody get boosted3g in here, he's got lots of experience with LS cams
[Modified by Speed PHreak, 10:22 PM 1/25/2003]
Old Jan 25, 2003 | 07:52 PM
boosted3g's Avatar
Default Re: Crower Cams (Speed PHreak)
The 402t cams are the best Ls cams you can buy off the shelf for a turbo car that you dont want to rev it too far past the redline. The 403s work well at slightly higer rpsm and the 404s make great power but youll have to rev the hell out of it. I was making power well over 9k with the 404s and it was still making more power the higher i revved it and i had it up to 10K before my ecu wouldnt handle anymore. Im sure WEB cams has my grind still in thier records and that is the cams that i made about a year ago. It is by far the best, i know a few guys are running it and i was given nothing but praises on it. If i remember correctly it was a 208 duration with a .479 lift. It makes power everywhere but it is not the easiest on the valvetrain. Try giving WEB a call and ask for the cam Josh Turner had and hopefully can make another one for you. I havent talked to them in quite a while since i went ls/vtec. If there is enough interest ill call them and see if they will make a few more for you guys.
Scud
Mar 8, 2006 07:09 PM
All Day
Jun 19, 2004 07:40 PM
4U2NV
Jan 14, 2002 07:42 PM
