Normal EGT readings? Experienced informative post only please!
Old Jan 22, 2003 | 11:13 AM
KStuned's Avatar
Default Normal EGT readings? Experienced informative post only please!
Ok, what should be normal readings on my EGT? I am currently assembling my h22, and it should be running within the next 2 weeks, depending on a few variables, but I want to get a feel of what I will be seeing as far as exhaust gas temperature. What temperatures are you guys seeing during heavy acceleration, part throttle, idle, etc. And at what boost levels, timing, etc. My gauges are greddy and are in celsius, so be sure to include whether it is in Fahrenheit or Celsius. Thanks.
Old Jan 22, 2003 | 11:35 AM
TurbothisLS's Avatar
Default Re: Normal EGT readings? Experienced informative post only please! (Hondaddict)
430ish at idle
730ish at 80mph cruise
greddy gauge
Old Jan 22, 2003 | 11:43 AM
Drag_On's Avatar
I run 1150 EGT's at 10 psi on my Mazda KLO3 motor.. Has nothing to do with your H series, but you get an idea what EGTs pull on a 10psi motor..
Farnsrocket's Avatar
Default Re: Normal EGT readings? Experienced informative post only please! (TurbothisLS)
B18C1 2.0 liter built GE block, 9:1 JE pistons, XS Engineering IC and JG Edelbrock mani, timing is 16 degrees advanced, Hondata 4b, NGK BKR7E11's.
Greddy Gauges in Celsius:
Under 1 BAR boosting, 3rd gear redline pulls through 5th on the highway starts to climb to 800
80mph highway cruising is about 700 or so. In the city it stays at 600 or so.
If I sit long enough, it drops under 400 idling....I wanna say 300.
[Modified by Farnsrocket, 12:46 PM 1/22/2003]
Old Jan 22, 2003 | 12:34 PM
BudaKai's Avatar
Default Re: Normal EGT readings? Experienced informative post only please! (Drag_On)
That's kind of hot there. You should try to keep it around and below 800*F
Old Jan 22, 2003 | 12:53 PM
Anubyss's Avatar
Default Re: Normal EGT readings? Experienced informative post only please! (tzsir)
800 F at idle (after warm up ). Around 1125 F cruising around. 1400 F at boost. This is on a 97 Prelude.
Old Jan 22, 2003 | 12:54 PM
simple4012's Avatar
New User
your thinking celcuis
mskibbz-T
Aug 26, 2003 09:38 PM
shadowdawn
May 22, 2003 01:42 PM
TurboDANDEE
Feb 26, 2003 01:46 PM
rexboy04
Oct 24, 2002 03:10 PM
