another happy automapper.
Old Jan 22, 2003 | 08:27 PM
wicx's Avatar
Default another happy automapper.
hey guys i had to share that having the capibility to automap is great. just got it working PROPERLY ie. a/f setup map calibrated etc. thanks to falcon for the help! ..was able to hit .5 bar with consistent and safe a/fs...
off to have more fun.. AEM +TECHEDGE WIDEBAND = FUN!
Old Jan 22, 2003 | 08:46 PM
highbrid's Avatar
Default Re: another happy automapper. (wicx)
all this automapping talk makes me want a wideband, who has good prices for these?
Old Jan 22, 2003 | 09:40 PM
wicx's Avatar
i got mine from techedge ... they have version 1.5 out now you should jump on it
Old Jan 22, 2003 | 09:50 PM
sharkcohen's Avatar
Damn my auto tranny, I want the AEM EMS sooo bad. And I have the TE V1.5, too.
Old Jan 22, 2003 | 10:05 PM
LJR-LUDE01's Avatar
sound good... what your set up? hpefully I find the sensor to install my WB
Old Jan 22, 2003 | 10:37 PM
highbrid's Avatar
Default Re: another happy automapper. (LJR-LUDE01)
im looking at this techedge unit...
V 1.5 Package Deal 2.6 - TE-WB Unit with 2.6 m (~8.5') sensor cable, and data acquisition cable & TE-5301 display (saving of $20). @ AU$540
is this a good kit and is it easy to understand/install. also is this the correct unit to use with aem ems?
Old Jan 22, 2003 | 10:40 PM
highbrid's Avatar
so did you set up your techedge just like falcon's because itd be cool if they could be set up the same on every car, but i doubt thats the case. do you have large injectors and can you just plug in the o2 and start the car with a base calibration if you have say...750cc injectors, for a hypothetical example.
Old Jan 23, 2003 | 12:16 AM
J2turbo21's Avatar
Default Re: another happy automapper. (highbrid)
How can you order your techedge if you dont have paypal,i was confused on the site.Do i just use my CC#?Post some specs of your setup.
[Modified by J2turbo21, 9:17 AM 1/23/2003]
Old Jan 23, 2003 | 12:20 AM
sharkcohen's Avatar
Remember, you also need to pick up a five wire sensor. http://www.thepartsbin.com frequently has them in stock for around $150. Yes, it is very easy to install, I just installed mine last weekend. One power wire, one ground wire. Mount sensor in exhaust (I had a local exhaust shop weld a second O2 sensor bung into my header downpipe). Plug in cable between sensor and unit. Plug in display. I don't know what is involved with making it work with the AEM EMS, but I know it's been discussed.
Old Jan 23, 2003 | 12:22 AM
sharkcohen's Avatar
Default Re: another happy automapper. (J2turbo21)
If you don't want to use paypal but you do want to use a credit card, they have to be able to verify your street address by looking it up via your home phone number. That means that if you have an unlisted number, they cannot verify your address and will not accept the transaction.
Old Jan 23, 2003 | 12:59 AM
LJR-LUDE01's Avatar
Default Re: another happy automapper. (sharkcohen)
you can also get it from NAPA ... right now the one in the partbin has the price of 299.00 and napa is backorder...
Old Jan 23, 2003 | 07:48 AM
highbrid's Avatar
it looks like the techedge unit that i posted comes with a sensor, correct me if im wrong, im sure you will.
Old Jan 23, 2003 | 12:03 PM
wicx's Avatar
the techedge unit does not come with an o2 sensor. i bought mine from the partsbin for like 150 dollars I post pics later. and yes I hooked up the close loop system like falcons...
got wide
Engine Management and Tuning
Sep 11, 2008 07:26 AM
civdx94
Feb 24, 2008 05:25 PM
miamidamian
May 11, 2006 07:36 PM
