How much boost can i run????
Old Jan 21, 2003 | 11:57 AM
boosted_zc's Avatar
Default How much boost can i run????
I want to make sure i'm not gonna over do it on the boost, so i'm posting this to get some opinions.
I have: sleeved ZC block from JG Engine Dynamics ( will be posted later)
: SRP FI 8.5:1 Pistons
: Eagle H-beam rods
: T3/T4 ( it's getting a stage 3 exhaust turbine)
: JDM Supra intercooler ( will probably upgrade to a Spearco or similar)
Also like to know what cc injectors i should use.
I'd like to run in the 20 psi range (don't laugh) , so with my components i'd like to know if this is possible. Thanks
Old Jan 21, 2003 | 12:04 PM
RyanAutry's Avatar
Default Re: How much boost can i run???? (boosted_zc)
I would assume 20+psi
I'd go with 720cc so you won't ever have to worry if you have enough fuel.
reXem's Avatar
What Fuel Management are you using? How much did it cost for JG Engine Dynamics to sleeve your block? Whose sleeves did they use? their own?
20psi on a sleeved fully built ZC should be easy as long as you have the proper engine management, ZDyne is pretty much the preffered one for non-obd cars.
When I have finished building my ZC I will be running 20psi on the street and 25 at the track. As for injector size I dunno, I havent gotten that far for my research as I still trying to find someone to resleeve my block. If your block is sleeved why do you need to post it? A GE Sleeved block will handle 40psi so I would hope the JG would handle 20psi.
Old Jan 21, 2003 | 12:13 PM
boosted_zc's Avatar
Default Re: How much boost can i run???? (reXem)
As for fuel management i'm probably goin with Zdyne, i've heard alot of good things about it. As for how much my block was, you'll never believe me and call me a liar, but it was only 350 plus shipping. It was in there specials section about a month ago. I believe it's there sleeves. I'm goona post it just for the hell of it, it doesn't cost that much money.
Old Jan 21, 2003 | 12:27 PM
reXem's Avatar
350!!! what is there website, is it still available?
Old Jan 21, 2003 | 12:35 PM
boosted_zc's Avatar
The site is http://www.jgenginedynamics.com , go under internet specials. I justed checked it though and they don't have any blocks left. But my proof is there though, zc bare block resleeved for $350. But drop them a line they might be able to help ya. Talk to Miguel, thats who i dealt with
Old Jan 21, 2003 | 02:30 PM
92HB_HB's Avatar
hey boosted _zc
is it Warren, as in Warren, MI??
just curious..
slammedobd1teg
Apr 16, 2009 05:38 AM
VTgringo
May 28, 2003 11:01 PM
VTgringo
May 27, 2003 03:02 PM
gigantor
May 22, 2002 02:53 PM
*Boostwerks*
Mar 21, 2002 11:52 AM
