to those with msd and stock coil, how did you do it?
to those with msd like 6btm, 6a, 6al & etc and STOCK COIL, did you guys hook yours like in this site: http://www.c-speedracing.com/howto/msdbtm/msd.php which is, drilling a hole on the stock distributor cap and using female spades to connect the wires inside?? if not, then how did you do yours?
Re: to those with msd and stock coil, how did you do it? (_Endless_)
Get the MSD converted cap and blaster coil, the stock coil is the weakest thing in the ignition.
But yeah, the C-speed is the way to go. Just make sure your wires don't touch the rotor inside! Ooooh!
That's the only way to do it with a stock coil. One way or another you have to run the stock coil wires out and the coil wires from the MSD back in.
I drilled a hole in my distributor though when I first put mine in like 4 years ago and used a gromet. Nice and neat and the wires don't get all funked up when you take the dist cap off.
I also used a 2 position terminal strip to connect the wires. Just a little touch of class
You can get something that converts your stock dis cap to an external coil cap.Its a msd part and cost about 13bux.3x less than the modded msd cap and works just as good.I have one on my gsr motor.
Re: to those with msd and stock coil, how did you do it? (J2turbo21)
Here's one related, but not not on topic:
How did you run your MSD with the ECU? Do you still use the ECU timing pulses or did you just by-pass it with a "faker" box? I wanted to use an Electromotive unit because I'm still using a stock one after 6 years. I think it's time to upgrade so I don't get that nasty back fire all the time when the revs are dropping. I just don't know if I need to have the ECU pulse's or not.
