JG Edelbrock Manifold Installation?
Just got my JG Edelbrock intake manifold . I can't seem to figure out were everything is supposed to go. There are a bunch of holes on the underside still and I am missing a spot for one of the sensors that has a vacuum line going into it. Also the attachments that are on the side of the stock manifold kinda looks like a throttle cable but Is on the opposite side? My manifold did not come with anything but the manifold. No parts no directions just the part. Someone please help me out with pics or something. I know someone is running this. I have an 01 GSR if that makes any difference.
Re: JG Edelbrock Manifold Installation? (18gTeg)
installation is pretty much straight forward. you're going to need a vacuum for the brake booster, fuel pressure regulator and pcv valve. you can either plug up the rest of the holes or use those as vacuum sources for your turbo "stuff". as for the throttle cable, i used a LS cable bracket along with a SOHC throttle pulley. you will not be able to use the GSR throttle pulley or bracket. i hope that helps...
B18C5-EH2
04-12-2005 02:32 PM
W O T
Welding / Fabrication
01-29-2005 02:10 PM
