DIY Additional Injector Controller?
Old Jan 21, 2003 | 11:19 AM
spike's Avatar
Default DIY Additional Injector Controller?
Just an idea I had.. but is there anyway to make a DIY additional injector controller? Maybe by using an AFC? There's got to be an easy way to run a couple extra injectors without paying the 600 dollars for an AIC. Anyone know?
thanks
Old Jan 21, 2003 | 11:30 AM
spike's Avatar
Default Re: DIY Additional Injector Controller? (spike)
Here's what I had in mind.. I would run the usual AFC hack.. and then inline I would splice into a injector line.. and have some sort of potentionmeter to adjust the duty cycle of that injector.. so I would have 8 injectors total.. just like an AIC.
Old Jan 21, 2003 | 11:38 AM
Smashback's Avatar
Do a search on google for "5th" or "fifth" "injector". That should bring up some stuff....I've seen a lot of people build little cheapy controllers for an extra injector. I thought about doing it but figured it would be better to do it right...by using the AFC hack getting Hondata now though!
[Modified by Hatchblack, 8:38 PM 1/21/2003]
Old Jan 21, 2003 | 11:42 AM
JM Performance's Avatar
used mf2s go for pretty cheap....under 200 and you'll get the injectors.
Old Jan 21, 2003 | 11:45 AM
spike's Avatar
Default Re: DIY Additional Injector Controller? (00SilverLS)
is it worth doing that and also running the afc hack? could i possibly boost higher than the 10 psi everyone recommends on a stock motor? or will the tuning be too hard to get it tuned fine enough to run more boost?
Old Jan 21, 2003 | 12:29 PM
Joseph Davis's Avatar
Search DIY-EFI for an additional injector controller schematic and program. It's a little more complex to implement properly than you'd think. It takes all the same equipment and more, more time, and more expense than what I propose below.
FYI, combining an AFC "type" of hack with a chip for your ECU is the most reliable way for those of limited funds - it just happens to cost about $100 which is cheaper than an SMC and doesn't butcher your ignition curve like the usual AFC/SMC hacks.
https://honda-tech.com/zerothread?id=373528
FYI, I'm covered up between projects, work, school, and inundated with broken ****. I'm more than happy to give a quick email pointer to someone who wants to DIY like I have, but if you want someone else to do it for you talking to filetofit about getting the chip burned is your best bet.
boostedteg4dr
Nov 30, 2013 01:17 PM
bigsnorlax
May 21, 2011 01:42 PM
b17a1crx
Sep 10, 2006 07:27 PM
Rare BlueSI
Sep 15, 2003 05:51 AM
Elite Hatch
Sep 18, 2002 01:34 PM
