how much can i run?
Old Jan 21, 2003 | 08:18 PM
boostedinteg03's Avatar
Default how much can i run?
Im wondering how much boost i can run on my stock internals with a 35shot of nitrous. I was thinking like 8 or 9 psi on race gas. My car is an ls with an automatic, what should i run in the 1/4 mile with that combination?
Old Jan 22, 2003 | 05:48 AM
TeStUdO's Avatar
Default Re: how much can i run? (boostedinteg03)
what kind of fuel setup are you gonna be using and what kind of tuning are you doing?
Old Jan 22, 2003 | 07:02 AM
Default Re: how much can i run? (00si5)
I just have a inline fuel pump and a vortech fmu.
Old Jan 22, 2003 | 07:45 AM
Elite Hatch's Avatar
Whoa man...With stock injectors you will not be able to push the amount of fuel need to supply 9lbs of boost and a 35 shot. Please do some homework about this. Im not trying to dog you but from the post it seems like you are jumping ahead of yourslef a bit. Turbo and N/X combos are very hard to do. They are a very good way of making good power, but for someone new to the whole forced induction thing. I would say that its a bad idea. You are running an auto trans, before anything I would do a tranny swap. Just my 2 cents
[Modified by Elite Hatch, 11:47 AM 1/22/2003]
Old Jan 22, 2003 | 08:14 AM
autoEXturbo's Avatar
Default Re: how much can i run? (Elite Hatch)
You are running an auto trans, before anything I would do a tranny swap. Just my 2 cents.
I completely agree. before you start saying you guys don't know what your talking about. Rt. 301 is a graveyard for my auto tranny and i was only running 8psi off the greddy 15g. Becareful with doing alot on the auto. It can be a good idea to run the auto if you have it built, but i have yet to see a streetable drag automatic for a honda. I'd say for fuel though since you already have and fmu. FMU 12:1 disk, paxton fuel pump, bigger lines, missing link, 550cc injectors at least.
Edit: I'd say you'd beable to run around 8psi and nitrous. Around 1bar without nitrous.
[Modified by autoEXturbo, 12:16 PM 1/22/2003]
Old Jan 22, 2003 | 12:11 PM
turbosol's Avatar
Default Re: how much can i run? (autoEXturbo)
12:1 mu and 550cc injectors??? I don't think that is a good route.
Old Jan 22, 2003 | 12:28 PM
Default Re: how much can i run? (turbosol)
why do you say that. I'm gonna run somewhere around 720cc's or bigger on my 12:1 FMU. I run 440's and have ran 550's, both run fine.
BudaKai's Avatar
I can't remember where I saw it, but there's a beefed up torque converter available. I don't know if that's what likes to blow up or not, but I've seen it.
Old Jan 22, 2003 | 12:43 PM
autoex how are you gonna get your car to idle?
Old Jan 22, 2003 | 12:47 PM
Good question, I'll have to figure something out. Maybe i'll only do the 720's if i go hondata. To many decisions, to little money not to get it right the first time.
Old Jan 22, 2003 | 01:14 PM
Yah idling would be the only problem. I have 440s and my low throttle is at -50 so I cant go any lower so If I did bigger injectors I wouldnt be able to idle
Old Jan 22, 2003 | 01:21 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: how much can i run? (tzsir)
ZEX........they just made one the bigging of this year http://www.zex.com 1-888-817-1008. I would advise the tranny swap as well. I had a civic that was automatic and i used nitrous. after 1 month my tranny continued to tear up. When normal driving it would shift really hard in first gear and somtimes in second. So if i were you to safe your tranny do the tranny swap. I know!
Old Jan 22, 2003 | 01:23 PM
Yea, i have so many different idea floating thru my head. I think i was considering the 720's if i went with hondata or something like that. Wow, i'm at -25 with my 440's and idle perfect.
primerk5
Aug 21, 2008 10:55 AM
wzcb08
May 11, 2003 07:36 PM
boostedinteg03
Mar 2, 2003 07:31 AM
Hyjnx
Dec 22, 2002 07:40 PM
JM Performance
Dec 5, 2001 05:03 AM
