fpr question
Old Jan 21, 2003 | 11:24 PM
Bongnak's Avatar
Default fpr question
I was just reading about fuel pressure regs and wondered if I can just use a regulator set at i higher psi to run slightly richer when boosting
lets say I want to increase the fuel in my crx can i put the 92+ regulator to do that since its set at 41-47 psi- about 10 psi more than stock 88-91?
or maybe another regulator thats ser higher havent looked for a list of specs yet but yeah can i?
Old Jan 21, 2003 | 11:50 PM
Stu's Avatar
Stu
New User
Default Re: fpr question (Bongnak)
I kind of understand what you are talking about. So, yes, if you are asking what I think you're asking, then that's what a fuel pressure regulator does. (I think)
Old Jan 22, 2003 | 01:45 AM
BudaKai's Avatar
Default Re: fpr question (Stu)
It would raise your AFR, but you'd be stinky rich at idle and lean out in upper areas under boost (not a good idea). If your going to try something like that just get a used FMU.
astig* DC2
Jul 13, 2005 02:04 PM
b18c1wes
Feb 12, 2004 09:12 PM
toooslow
Jun 13, 2003 04:06 PM
CiViCMiNDed
May 22, 2002 11:14 PM
