does the stock oil pressure sending unit have to be hooked up???
is it neccesary to hook this up or can i leave it unconected??? i have an aftermarket oil press guage and i want to put it in that port without running a tee or simmilar system???
Re: does the stock oil pressure sending unit have to be hooked up??? (hooked_up_gsr)
no you dont need to use the stock sensor, you take that out to put the aftermarket sending unit in . but i ran a t then for my feed line, where are you runnign your feed line from . thats the way that 90%of the people do it here
Re: does the stock oil pressure sending unit have to be hooked up??? (itr206)
im using a golden eagle oil filter adapter...im pluging the -5 port and using the -3an port to run oil to my turbo. i had a tee for it before and it broke so i m not dealing with that again.
okyea thne the pressure sending unit will make you striaght then .
