Need Expert Electrical Help... Hooking up alarm to turbo timer
I have an avantigaurd 4 and I dont know which wires I am suppost to hook up my apexi turbo timer wires to so that the alarm will arm and the car will keep running. I have quite a bit of electrical experience but just need to know what wires and why. Any help is greatly appriciated. Thanks from James.
Re: Need Expert Electrical Help... Hooking up alarm to turbo timer (400WHPITR)
All i know is a relay .. I have a viper ESP 550 and I have to wire one in too. Is this the Tt that looks like a pencil? If so I like that one and will get the same one.
bump ... and dont say search
I have a Clifford AG4 too, and it's supposed to have a built-in turbo timer actually. Anyone know how to use this feature? I have the Cliffnet Wizard too and I didn't see the settings in the software for that.
::Bump::
::Bump::
wire your trigger (most of the time its yellow or orange)to an acc wire that doesnt stay on when the car is running and the ignition is turned off. Usually its a wire that only turns on when the key is turned all the way to the second point just before starting and not on the first click of the key ignition. Sounds confusing but when you test the wires youll find the right one. Hope it helps.
Re: Need Expert Electrical Help... Hooking up alarm to turbo timer (proclassracer)
go to http://www.pfispeed.com click on tech help and once in under tips click on phrase and color diagram should come up.
[Modified by luckypon7, 10:24 PM 3/21/2003]
400WHPITR
Audio / Security / Video
03-31-2003 02:53 PM
Lei Siew Long
06-30-2001 12:17 AM
