A few trubo questions
Old Mar 16, 2003 | 07:54 PM
DA MAN's Avatar
Default A few trubo questions
Hey guys I have a JDM B18c and I wanted to turbo it but I have a few questions. I’m thinking about getting the rev hard stage 2 kit. I know that I will need bigger injectors and a high volume fuel pump. My question is do I need to get an inline pro head gasket to lower the compression. I want to run between 8 and 11 psi any info will be helpful.
Old Mar 16, 2003 | 08:10 PM
b16ahybrid's Avatar
Default Re: A few trubo questions (DA MAN)
You should be fine up to about 10psi or so.
If you go the vafc/hack you should be fine up to about 10psi.
440's, high volume pump and vafc should do the trick.
Old Mar 17, 2003 | 04:01 AM
DA MAN's Avatar
Any thing eles you guys think I should get before I turbo it. Also about how much hp do you think I will have at 10 psi.
Thanks
seanjohn81
Jan 23, 2007 04:46 PM
brandond
Apr 29, 2004 04:47 PM
UNDER PRESSURE
Dec 19, 2002 02:56 PM
Hondakiller
May 21, 2002 05:07 AM
00 Si
Jul 3, 2001 03:13 PM
