lowering your compression?
Old Mar 19, 2003 | 04:24 AM
Charlie Moua's Avatar
Default lowering your compression?
can you please add to my list of possible ways to lower my 11:1cr motor without changing out pistons:
1) greddy head gasket=...what is my new cr????
2) cosmetic head gasket=? fill me in on this... I'm not to familar with it.
3) ?????
Old Mar 19, 2003 | 04:33 AM
Evil EG's Avatar
Default Re: lowering your compression? (Charlie Moua)
A headgasket period! Will do it.... Or sand down the top of your pistons.
Old Mar 19, 2003 | 04:39 AM
QCKGSR's Avatar
cometic head gaskets make different thicknesses and they will all effect you cpr. differently.. , is your chamber volume stock, what is the dish/dome volume in cc's.... what is the bore size.... how much is th e piston in the hole in .000"... and how much volume is your head gasket gonna take up... meaning if you laid the gasket on the ground and filled one of the bores up with water how many cc's would it take?? these are some of the questions you need to answer to be able to accurately determine your cpr.... im if you need help
Old Mar 19, 2003 | 06:12 AM
Default Re: lowering your compression? (QCKGSR)
I IM you
WorrGame13
Mar 30, 2007 03:35 PM
silentdaredevil2
Nov 24, 2005 12:29 PM
doublejz
Aug 6, 2005 08:06 AM
AWDxBOOST
Sep 28, 2002 10:18 PM
Ltech
May 17, 2002 04:05 AM
