Profec B took a shit!!!! HELP PLEASE!!!!!
Old Mar 18, 2003 | 04:42 PM
T25 civic's Avatar
Default Profec B took a ****!!!! HELP PLEASE!!!!!
I've only used my profec b for maybe 4k miles and today was the first time I try to up the boost at all. After messing with it for about 12 pulls I finially gave up because no matter where I put the settings the boost would not change. I contacted the GReddy tech help line from their website and they asked me if the control module under the hood was clicking when turned on and its not. Now they want me to send it to them for inspection and I don't know what to do. Does anyone have any suggestions? Has anybody had any problems like this at all? What could cause the clicking to stop?
Nick
Old Mar 18, 2003 | 04:55 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: Profec B took a ****!!!! HELP PLEASE!!!!! (T25 civic)
when you say , no matter where you put it the boost wouldnt change. do you mean the boost will go over whatever the wastegate spring is?? the profec only goes 14lbs over whatever the spring is up to 28psi. there is away around the 28psi deal but thats another story. give us more info to help you
Old Mar 18, 2003 | 05:11 PM
T25 civic's Avatar
Default Re: Profec B took a ****!!!! HELP PLEASE!!!!! (MotorMatrix.com)
I have an aftermarket canister so its set at 4psi, and no matter where I move the settings on the controller in my car the boost stays at 4psi. I want to run 8psi and I've spent 400 dollars on this controller and it doesn't even work.
The greddy tech line says that the controller that sits under the hood should click, but mine doesn't. It did when I first installed it but not now. What could this be?
Any help?
Nick
Old Mar 19, 2003 | 01:44 PM
T25 civic's Avatar
anyone?
Nick
Old Mar 19, 2003 | 02:15 PM
avividmemory's Avatar
has it worked before...or is this a new install...maybe you hooked it up wrong, just a thought
edit: sorry im retarded i didnt read it well enough...i dunno what to tell ya
[Modified by SpoolinLS, 6:16 PM 3/19/2003]
Old Mar 19, 2003 | 05:20 PM
BoostedSi's Avatar
Default Re: Profec B took a ****!!!! HELP PLEASE!!!!! (SpoolinLS)
i dont remember my profec b ever clicking...hmm
[Modified by BoostedSi, 2:20 AM 3/20/2003]
Old Mar 19, 2003 | 05:32 PM
1fstevo's Avatar
New User
Default Re: Profec B took a ****!!!! HELP PLEASE!!!!! (BoostedSi)
it clicks when you switch from low boost to high boost.
I suggest you click on high boost and turn it up to see if it works. If it does then mess around with low boost.
The vacuam has to be hooked up right or else nothing works.
Old Mar 19, 2003 | 06:57 PM
T25 civic's Avatar
Default Re: Profec B took a ****!!!! HELP PLEASE!!!!! ([Evo]Hybrid)
I've changed the vacum lines twice. The vacum lines are setup perfectly. The tech at greddy said the controller should click when the solenoids are working. I'm taking it to a local greddy authorized dealer to check it out on friday but any other tips are welcommed!
Nick
Old Mar 19, 2003 | 06:59 PM
IloveNewt's Avatar
How r u running the vacum lines? Im having same problem, it wont boost past 13psi. Someone told me to try to change it to an internal wastgate setup. But ive got other problems on my hand before i worry about upping the boost.
[Modified by MordecaiPSI, 3:59 AM 3/20/2003]
Old Mar 19, 2003 | 07:04 PM
I am a bad person
it definetly clicks when switching from low to high boost. i know that much.
Old Mar 20, 2003 | 07:24 AM
SiR Kid's Avatar
New User
Mine clicks, and it's great. we tuned my car precisely at 1 bar, .9 bar, .8 bar, .7 bar, and .45 bar <spring level>.
I my Profec B.
Old Mar 20, 2003 | 06:16 PM
T25 civic's Avatar
Default Re: Profec B took a ****!!!! HELP PLEASE!!!!! (SiR Kid)
Yeah I', going to the autorized dealer tommorow to have them inspect it. They said it sounds like my controller under the hood isn't working. They are going to switch it out with a known good one in their garage to see if thats the part that is not working. Then we can go from there.
Nick
Old Mar 20, 2003 | 07:12 PM
niedejb's Avatar
I had the same prob.
Had to plumb it the following way (against all diagrams).
Nipple on the compressor to in (could be from manifold if you want)
Out to the side of the Tial (leaving the top open to air).
I know this isnt the way Greddy shows, but its the only way I could get mine to work.
Old Mar 22, 2003 | 07:31 AM
T25 civic's Avatar
Default Re: Profec B took a ****!!!! HELP PLEASE!!!!! (niedejb)
yeah but I have no tial to hook it up to so I couldn't hook it up like that. What I was told I need to do is actually unistal everything and send it back to greddy for waranty inspection.
Nick
Old Mar 22, 2003 | 09:26 AM
niedejb's Avatar
Nick
If you only have one port use it. I swear itll work. It only takes a second to swap em around and try it.
Old Mar 22, 2003 | 04:34 PM
T25 civic's Avatar
I don't think you understand. I have an internal wastegate, they can only be hooked up one way.
nick
Old Mar 23, 2003 | 08:16 PM
T25 civic's Avatar
I went ahead and uninstalled it today and switched the dipswitches on the back to internal wastegate for over-boosting. The god damn thing works now. I dunno why or how but the damn thing works now! I'm happy!
Nick
Old May 1, 2003 | 07:01 AM
djmatix's Avatar
i remember one time I was messing with my car and then all of a sudden, my profec wouldnt boost past 5psi. I was on my way down to blanding blvd in jax. to partake in some racing...turned out, when i put my strut bar back on, I crushed one of my vacume lines under it. So it was like I was running stock boost.
Old May 1, 2003 | 10:32 AM
Muckman's Avatar
Moderator in Chief
Default Re: Profec B took a ****!!!! HELP PLEASE!!!!! (djmatix)
Im a turbo newb but i thought your controller could only allow as much boost as the spring is set for. controller = less than or equal to spring?
Old May 1, 2003 | 02:47 PM
niedejb's Avatar
Default Re: Profec B took a ****!!!! HELP PLEASE!!!!! (Muckman)
It can only control DOWN to the wg spring rating.
i.e. cant use a boost controller to get 6 psi on a 10 psi spring.
_kiid
Nov 18, 2009 04:12 PM
turbotime
Sep 11, 2006 12:46 PM
adseguy
Nov 12, 2005 09:26 AM
integ2
Jun 15, 2004 06:44 PM
T25 civic
Mar 19, 2003 01:44 PM
