Boost pressure?
Old Mar 19, 2003 | 12:07 AM
94hondaLS's Avatar
Default Boost pressure?
I planing a T3 setup for my B18b hatch and was wondering how much boost I can run safely (as in reliable) with a FMU only. Any reasonable opinion is much appreciated. Also APROXIMATELY how much power increase should i expect from it. thanks again.
Old Mar 19, 2003 | 05:37 AM
SOHC_power's Avatar
Default Re: Boost pressure? (94hondaLS)
You might want to do a search on this to see what kind of numbers poeple are putting down with that setup. I wouldn't run more then 5-6psi on stock injectors. I ran 10psi for a couple of months and my injectors are screwed. Waayyyy too much fuel pressure for stock injectors. Guess I'm gonna have to fork over the cash for hondata and some 440's. Good luck!
Old Mar 20, 2003 | 01:52 AM
94hondaLS's Avatar
Default Re: Boost pressure? (SOHC_power)
bump
Old Mar 20, 2003 | 02:12 AM
Tofurky's Avatar
you're gonig to use an inline pump right?
but i wouldn't touch higher than 6psi.
i'm not just jumping on the bad mouth fmu wagon, i fried rings at 8psi with a 12:1 fmu. **** luck, i know.
japspecb7
Jul 22, 2008 04:59 PM
GOLDBERG
Apr 13, 2003 05:16 PM
Rah Rah
Feb 24, 2003 06:03 PM
InfamousRS
Oct 15, 2001 04:36 PM
Giuseppe
Oct 10, 2001 09:23 PM
