post your BOOST TIMING setups
Old Mar 19, 2003 | 06:21 AM
untitled's Avatar
Default post your BOOST TIMING setups
please post how much boost you are running and how much timing you re running and how didi you set the timng(BTM, moded dizzy, etc) and any other significant #'s you think are relevant. thanx
Old Mar 19, 2003 | 06:25 AM
Xscream's Avatar
Default Re: post your BOOST TIMING setups (88crx91integra)
6.5 PSI, -3 degree
Old Mar 19, 2003 | 06:28 AM
untitled's Avatar
Default Re: post your BOOST TIMING setups (Xscream)
how did you achieve this? with a btm or ........? the reason i ask is because i want to know if there is a free way to retard the ignition so i dont have to spend $ on a btm.
TurbodCX's Avatar
With the hondata i am running.
12psi @ 21 degrees by the romeditor
Brian
Also i am going to run alot more on race gas..
Old Mar 19, 2003 | 06:56 AM
b18cTurbo's Avatar
Default Re: post your BOOST TIMING setups (TurbodCX)
mine is set at .70deg per psi and i start retarding at 5 psi (that whit 9:1 compression and 94 octane rating)
if i had higher compression like 10:1 i would start retarding at 1 psi
also depend on what octane rating your using
so becareful every setup is different
good luck
Old Mar 19, 2003 | 06:57 AM
mamaboy's Avatar
https://honda-tech.com/zerothread?id=393316
This should help you out....the free way...well you need a timing gun
Old Mar 19, 2003 | 07:11 AM
untitled's Avatar
Default Re: post your BOOST TIMING setups (mamaboy)
do the btm's retard as boost increases or do they have a set retard.
Old Mar 19, 2003 | 07:13 AM
b18cTurbo's Avatar
yes 1-5 psi start retarding mode
Old Mar 19, 2003 | 07:26 AM
sharkcohen's Avatar
EFI PMS, .75 deg/psi
Old Mar 19, 2003 | 08:03 AM
VTECPWR's Avatar
Default Re: post your BOOST TIMING setups (sharkcohen)
I thought with the PMS timing changes were in 1 degree increments.
Old Mar 19, 2003 | 09:05 AM
avividmemory's Avatar
Default Re: post your BOOST TIMING setups (VTECPWR)
anybody want to help me and tell me how your btm is installed on stock ignition...i cant tell if mine is working or not
Old Mar 19, 2003 | 09:25 AM
Mase's Avatar
Its kinda hard to give an exact number, because each motor is gonna run different stock timing at WOT.
I usually go by .7 degree of retard per psi.
Old Mar 19, 2003 | 09:54 AM
SuperT's Avatar
I usually start out with about 32 total(12 initial). I then taper it down 1 degree per psi boost starting at 7 psi...until I reach 20 total(so I pull out 12 total at any boost above 19psi). If you are going to go above 25psi, 18 or 19 total may be best to be on the conservative side.
Hope that gives you a good baseline to start from...
Dave
Old Mar 19, 2003 | 09:57 AM
LS-hatch's Avatar
Default Re: post your BOOST TIMING setups (SuperT)
i assume you cant afford hondata but I would still highly reccomend picking up the BTM, some people have no trouble living without it, but its not worth the gamble IMO
Old Mar 31, 2003 | 07:34 AM
Xscream's Avatar
At the distro
93civciv
Dec 4, 2007 05:23 PM
miro_gt
Sep 19, 2005 02:17 PM
InTeGrA B18b1
Dec 12, 2004 06:06 PM
Boost2NA
Sep 30, 2003 02:55 AM
hybrid901
Sep 11, 2002 05:33 PM
