Gathering info on turbo
Old Mar 18, 2003 | 11:22 AM
raene's Avatar
Default Gathering info on turbo
Hey guys... what's up. Just wondering where I can gather info on finally getting a turbo. I'm actually getting one yet - haven't decided my next move - so I want to look into the whole thing first, see how 'on the cheap' a turbo can be done - homebrew of course - and then compare my options .
So on that note, where can I find things like compressor VE maps? Hondata tuning options? Info on which cam is best for turbo? Info on basic turbo installs? How to check if the engine is in a good enough state of repair for a turbo install? I want to do this on the cheap but not ghetto-rigged - I plan on doing Hondata with only a small amount of boost, driveability is a must. I'm also the DIY type, so this will REALLY be a homebrew job Thanks to anyone who has info or can point me in the right direction!
[Modified by raene, 12:23 PM 3/18/2003]
Old Mar 18, 2003 | 11:25 AM
Ben Huynh's Avatar
Default Re: Gathering info on turbo (raene)
My advise is to do your homework (as much research as possible). Turbocharging your car will not be a cheap project and you want to do it right the first time. HT is the best place to get your research done.
Old Mar 18, 2003 | 11:29 AM
alpha's Avatar
I would search here for terms like "overlap", "hondata", "tuning", etc. You can find good Hondata tuners here and at http://www.hondata.com/ . I would recommend doing ALLOT of research before you put ANY money into your setup. Set some power goals (Example: 280WHP) and a budget (Example: $5,000).
91redteg
May 30, 2007 05:00 PM
sidious141
Apr 12, 2004 05:45 PM
