V-Afc hack on a JRSC Si
Old Mar 17, 2003 | 08:10 AM
GreddySi99's Avatar
Default V-Afc hack on a JRSC Si
I have had a friend of mine tell me that it is possible to do the hack on a JRSC car because the boost is after the throttle body. Is this true? I think he is full of it because the SMC that is currently on my car works fine and it reads boost the same way does it not???? Any way some clarifacation would be nice form some of the HT members. Thank you
Old Mar 17, 2003 | 08:20 AM
GreddySi99's Avatar
Default Re: V-Afc hack on a JRSC Si (intercooledJRSC)
ANybody have any concrete info on this???
Old Mar 17, 2003 | 08:29 AM
JRSCCivic98's Avatar
All you'd have to do is move the map sensor to see boost. If you leave the map sensor in the throttlebody like it is now, you'll never see boost on it with a JR. Your SMC isn't reading boost if your map sensor is in the stock location either. It basically boils down to wether or not you need the map to see boost, but you can run the hack with a super or turbo. You just need to make sure the map sees boost, that's all.
Old Mar 17, 2003 | 08:34 AM
GreddySi99's Avatar
Default Re: V-Afc hack on a JRSC Si (JRSCCivic98)
SO this guy is full of it I guess. I have the JRSC MAP controller relocation piece on the throttlebody. So My MAP does see boost. THat is what I had thought. Because the car runs fairly well with the SMC plus installed. Now it just need to be tuned.
Old Mar 17, 2003 | 09:22 AM
gitwidit's Avatar
Clarification please: What is the SMC plus?
Old Mar 17, 2003 | 09:27 AM
What the hell is that?? You don't need anything with a JR to keep the map from seeing boost. Because of the location of the map sensor in the stock location in relation to where boost is built (in manifold after the map only) you'll never see boost on a JR unless you take the map out of the throttlebody and put it in the manifold above the charger or run a line/hose to it from the manifold(boost side) to it.
Old Mar 17, 2003 | 02:08 PM
GreddySi99's Avatar
If you would read closer that is how mine is setup. It has the JR map mod piece so that the map sees boost.
Old Mar 17, 2003 | 02:28 PM
Sorry... must have been high at the time
I read it as "So my MAP doesn't see boost." That's why it didn't make sense... lol
Old Mar 17, 2003 | 02:34 PM
Can you elaborate on this... maybe snap a pic of it? Is it something you bought from JR? I just plugged up my TB hole and ran a vac/boost line to my map... always looking for a nicer way to do it if possible.
Old Mar 17, 2003 | 03:15 PM
Daniel's Avatar
Default Re: V-Afc hack on a JRSC Si (GITWIDIT)
like an updated version of the SMC: http://userwww.sfsu.edu/~ecg/smc.htm
hondaeg8
Jul 29, 2005 07:41 PM
cvclover
Sep 29, 2004 12:27 PM
csmsi311
Nov 28, 2003 03:02 PM
Pfieff
Jun 13, 2003 12:03 PM
Greyout
Jan 25, 2002 09:08 AM
