Possible bad tranny??
Old Mar 17, 2003 | 09:42 AM
b18cya's Avatar
Default Possible bad tranny??
I just finished installing my clutch (with the help of an experienced friend) & the car still doesnt move...
its acting as if the tranny isnt going into gear. its like i put it into gear at the shifter, but the tranny is staying in neutral.
im pretty sure the clutch is fine because when i let the clutch pedal up, the motor slows a little because of the added mass of the clutch disc & rotatin assembly.
i bled the cluch, & that didnt change anything either...
any ideas? things to try?
[Modified by b18cya, 11:43 AM 3/17/2003]
Old Mar 17, 2003 | 09:59 AM
93LSivic's Avatar
Default Re: Possible bad tranny?? (b18cya)
By chance did you install the disc backwards?? That would cause your problem.
If it was the trans you would have probably heard some type of noise---actually you will hear the trans mainshaft turning just by engaging/disengaging the clutch while in neutral.
Im guessing the disc is in backwards.
Old Mar 17, 2003 | 10:06 AM
b18cya's Avatar
Default Re: Possible bad tranny?? (93LSivic)
naw, the clutch disc cannot go in backward (i think). i already asked the guy i did the clutch with & he said it's impossible.
it's an Action 1MDS
Old Mar 17, 2003 | 04:33 PM
93LSivic's Avatar
No, it is possible to have disc in backwards. Maybe he didnt want to fess up that he f'd up
Old Mar 17, 2003 | 06:03 PM
mechanik's Avatar
shift fork lined up correctly? Enough brake fluid in clutch resevoir?
Old Mar 17, 2003 | 09:51 PM
b18cya's Avatar
Default Re: Possible bad tranny?? (mechanik)
is it possible to mess up the shift forks???
the only think i can think of is if we didnt align the shift linkages correctly. im gonna mess with that once it stops blizzarding outside...
Old Mar 18, 2003 | 03:04 PM
b18cya's Avatar
bizzujmp
Old Mar 18, 2003 | 03:43 PM
MachAF's Avatar
sounds like clutch wasn't install correctly.
Was it doing this before you changed the clutch?
http://www.c-speedracing.com
Check out their cluch install. See if you missed a step.
Old Mar 21, 2003 | 01:45 AM
b18cya's Avatar
Default Re: Possible bad tranny?? (machaf)
ok, tell me if im a cheapo or if this is ok.
im going to temporarily install my buddy's extra GSR tranny to try & isolate the problem. i just bought 3 quarts of MTF fluid which is now in the tranny. i dont really feel like buying another 30 bucks for MTF fluid for the next 2 tranny installs. can i just empty what i have now into a clean container & reload it into the new tranny?
Old Mar 21, 2003 | 04:55 AM
keithv's Avatar
if the fluid that comes out is clean then you can reinstall it. if the fluid is dirty i wouldn't put it back in the tranny...
i know on the older honda trannies, 10w30 motor oil is recommended. maybe use that if you are only going to have the tranny on the car for a short time.
Old Mar 21, 2003 | 06:18 AM
Farnsrocket's Avatar
Default Re: Possible bad tranny?? (breaka_1_9)
You can reuse that fluid......especially if the car hasn't moved.
Does the car feel like it is going to all the gears when you shift?
Old Mar 21, 2003 | 06:56 AM
SJP0tato's Avatar
Double check the axles where they go into the tranny, and make sure they're fully seated. Sometimes if they're out just a slight bit it'll look like they're in but won't engage the teeth in the differential and when you engage the clutch the differential just spins without moving the axles. Might wanna give 'em a quick look just to make sure first.
Hope it turns out to be somethin easy,
Ryan P.
Old Mar 21, 2003 | 07:25 AM
b18cya's Avatar
Default Re: Possible bad tranny?? (SJP0tato)
Ryan P.
damn...that might be it. i was just under it yesterday checking out the shift linkages, & i was looking at the passenger side axle. I didnt think much of it, but it looked like it was a few millimeters farther out than before I removed the tranny.
however, I can still put it in & out of any gear while the engine is running, without using the clutch pedal... so my friend tells me that there is something wrong with the shifting parts in the tranny. possibly broken or bent shift forks.
i found a set of all 3 shift forks for 110 shipped brand new. how much would it cost to have them installed? or have the tranny totally rebuilt?
[Modified by b18cya, 9:37 AM 3/21/2003]
Old Mar 21, 2003 | 08:16 AM
b18cya's Avatar
WTF...
i just called aamco, & told them i'd bring the tranny, new bearings, syncros, & shift forks & they quoted me 2100 for the rebuild??? wtf?
does anyoen know of any good tranny guys in colorado?
[Modified by b18cya, 10:16 AM 3/21/2003]
Old Mar 21, 2003 | 12:45 PM
mike1114's Avatar
Disc can go in the wrong way, did the part that raises up in the middle about a half inch (where springs are) face out toward you before you put everything else back on? IF not you put it on wrong way.
I may have your solution. I just did a clutch/flywheel instal on my Civic with GSR motor. When I put it all back together, it wouldn't shift at all, if It did shift, it was like I was not using the clutch and just jaming it into gear.
I finally figured out that the slave cylinder (part on the front of tranny that hydraulic line goes to) wasn't engaging the arm that comes out of the tranny, check to see if the ball on the slave cylinder is in the socket of the arm that comes out of the tranny. if not, pull off the slave cylinder and fit it back in.
Another thing was that we didn't bleed the lines good enough. U have to make sure you get ou all the air or it won't engage clutch all the way. Make sure when your bleeding you don't run out of fluid in the resiviour or you will have air in the lines all over agian.
Old Mar 21, 2003 | 12:47 PM
mike1114's Avatar
Default Re: Possible bad tranny?? (mike1114)
IF your even considering arebuilding your tranny, just buy another used one. I fucked up 1 and 3rd gear in a previous tranny and said screw it and just bought a used one for like $700.00
Old Mar 21, 2003 | 02:25 PM
b18cya's Avatar
yea, we put the clutch in the right way. the pressure plate doesnt fit on if the disc is on backwards.
yea, the slave cylinder & TO bearing lever/fork is all working correctly.
& we bled the clutch a few times with a vinyl tube & a cup of brake fluid. so im pretty sure its workin right.
Old Mar 22, 2003 | 09:31 AM
b18cya's Avatar
even if the axles didnt snap in place, the wheels should turn, correct?
Old Mar 31, 2003 | 10:33 AM
b18cya's Avatar
BUMP.
ok, i pulled the axles & put them back in & they're definitely in all the way.
does anyone have any more suggestions before i shell out the cash for a new tranny?
Old Mar 31, 2003 | 10:40 AM
NeoGSR's Avatar
i'm having the same problem with my new set-up....ITR tranny w/ ACT clutch
i can sometimes get the car into 1st and 2nd, but never reverse....3rd-5th work fine....
my axles are definetely in because both tires get power...i'm gonna bleed the clutch system and check the linkage tomorrow and try to manually shift the gears right from the outside of the tranny....maybe some bent forks or something???
bump for some help
13g-crx
Transmission & Drivetrain
Oct 4, 2011 08:20 PM
Poey
May 21, 2009 03:39 PM
Drian
Jul 21, 2004 07:56 PM
CimorelliCRX
Dec 15, 2002 04:02 AM
phatintegra
Mar 21, 2002 06:39 PM
