look what i found
Old Mar 16, 2003 | 05:57 PM
bretx0r's Avatar
Default look what i found
well recently i picked up a LS motor and well:
pretty aint it.
what the **** is this?
oh THATS what it is.
so guess what. all new rods/pistons/bearings/rings/studs
[Modified by bretx0r, 2:57 AM 3/17/2003]
Old Mar 16, 2003 | 06:10 PM
mos's Avatar
mos
Default Re: look what i found (bretx0r)
Self adjusting compression for those boost creep moments?
Old Mar 16, 2003 | 06:15 PM
slowEJ6's Avatar
Default Re: look what i found (mos)
time to put the turbo on.....mwahahaaaaaaaa
Old Mar 16, 2003 | 06:21 PM
bretx0r's Avatar
keep in mind i just took the head off cause i saw the diff between heights and i was like somethings gotta be wrong. Good thing i didnt do what id normally do and just blow it off instead of ask whats wrong.
Old Mar 16, 2003 | 06:23 PM
.RTErnie's Avatar
your going to need a couple of these
Old Mar 16, 2003 | 06:24 PM
BoostedSi's Avatar
did the person you bought the motor from say everything was ok with the motor?
DSGB.'s Avatar
Dirty Bird
Heights in what?
Old Mar 16, 2003 | 06:27 PM
BoostingSnail's Avatar
Default Re: look what i found (Blurple92si)
Heights in what?
heights in companion cylinders....1&4 cylinders are companions of each other.....when one is on the top of the exhaust stroke the other is on the top of the compression stroke
Old Mar 16, 2003 | 06:30 PM
APEX i GSR's Avatar
i took apart my GSR (spare) & found the same thing
i thought it would have cracked walls so i was actually happy
but it doesn't alter the price of the buildup at all though
good luck on your rebuild
Old Mar 16, 2003 | 06:49 PM
bretx0r's Avatar
Default Re: look what i found (APEX i GSR)
yeah. im thanking god everythings cool
Old Mar 16, 2003 | 07:00 PM
Danger's Avatar
man u have got a lot of **** for your car lately . i cant wait till you install that . lsturbo wat rods/pistons you going w/ ?
Old Mar 16, 2003 | 07:02 PM
bretx0r's Avatar
Default Re: look what i found (JonnyDanger)
i dunno it seems like its one thing after another... i was going to do stock LS till i saw this.
pistons/rods/bearings/studs/rings
prolly going to do wiseco pistons/eagle rods 9.0:1/ACL bearings/ARP studs/total seal rings (maybe)
should be a beast once the turbos in and its all tuned
[Modified by bretx0r, 4:48 AM 3/17/2003]
Old Mar 16, 2003 | 07:03 PM
boostaholic's Avatar
LOL!
Old Mar 16, 2003 | 07:05 PM
Danger's Avatar
prolly going to do weisco pistons/eagle rods 9.0:1/ACL bearings/ARP studs/total seal rings (maybe)
yes a monster .
Old Mar 16, 2003 | 08:11 PM
bretx0r's Avatar
ttt
i guess the reason why it was bent is narrowed down to a little water got into the motor and bent the rod so miniscuoley that it wasnt hardly noticeable until i pulled the head off.
[Modified by bretx0r, 5:17 AM 3/17/2003]
blackeg
Dec 9, 2014 10:59 AM
Machine1
Mar 2, 2012 01:56 AM
sirt_eg
Apr 8, 2009 09:31 AM
97accord_R
Mar 23, 2009 02:29 PM
H22_TURBO
Sep 19, 2006 07:58 AM
