For you guys that weld
Old Mar 18, 2003 | 07:22 AM
98AccordEX's Avatar
Default For you guys that weld
i didnt know where to post this and i figured most of the people that weld make manifolds so they would be in the forced induction forum
i dont know how to weld. i just wanna learn. i dont need to make manifolds. i really just wanna make exhaust then eventually after i have learned maybe make a manifold or two. i just dont know which kind of welder i need to weld pipes. stainless and mild steel. is this welder alright for this kind of stuff? should i just get something cheaper? do i need a TIG welder? what kind of gases do i need? so my question is pretty much - what the hell do i need to weld stainless and mild pipes? if you wanna recommend any other welder thats fine also. recommend whatever you want cause i really dont know. i just wanna learn and teach myself
http://www.sears.com/sr/product/summ...id=00920559000
Old Mar 18, 2003 | 07:27 AM
Overblown-Teg's Avatar
Default Re: For you guys that weld (98AccordEX)
finding a local weld shop would be a good idea. Those guys are normally very helpfull.
Old Mar 18, 2003 | 07:30 AM
BoostedH23a1's Avatar
Default Re: For you guys that weld (Overblown-Teg)
ive got a small one kinda like that and it doent work very well.. i like migs but mine doesnt shoot the wire out fast enough. every now and then it will speed up and ill get a decent weld.. but maybe its just the machine i use.. its a century..
Smashback's Avatar
I have a MIG. I'd really like a TIG but I don't have $1500 to drop on one right now. MIG works good, but not quite as pretty and depending on the one you buy typically won't work as well on thicker metals.
Look at Lincoln and Miller. Expect to spend about $400 or so for a decent one, plus about $100 for a small gas tank. For mild steel (and probably stainless) just ask them for the gas you need when you get the tank, they'll know (75/25 mix).
98AccordEX's Avatar
ok well since youre from Mechanicsburg too. where is one? i didnt know there was anyone from here on here. r u from Modified? i think i saw someone was but not sure of what the name was
Old Mar 18, 2003 | 07:45 AM
ykracing's Avatar
You might want to take a class in welding... you can learn a ton that way, and you can usually make whatever you want using the tools in class... class was $100 and I learned a ton.
Look into it at the local community colleges, and local adult education programs...
Old Mar 18, 2003 | 08:49 AM
paulzy's Avatar
Default Re: For you guys that weld (trboCIVIC&WRX)
that welder is good enough....but for the price, I'd get the miller/hobart 135....THe name says it all. Plus, the miller/hobart comes with a cart
Old Mar 18, 2003 | 09:13 AM
98AccordEX's Avatar
yeah i go to a community college and tried to take a class but it was either welding or english and that was the only times for the welding class. maybe i can next semester. thanks for the info guys
OutlawHonda
Welding / Fabrication
Dec 20, 2006 11:47 AM
Mr.E.G.
12
Dec 12, 2006 06:45 AM
Mr.E.G.
25
Dec 8, 2006 08:53 AM
rip94delsol
Oct 6, 2006 12:52 PM
