3" Down pipe Problem.
Old Mar 17, 2003 | 04:30 AM
TurbodCX's Avatar
Default 3" Down pipe Problem.
Ok guys,
i need to know where i can buy a 3" exhaust donut, not a donut gasket, but a 3" peice of pipe tHAT IS MANDRELLY BENT into a perfect circle,(donut)
i have seen them before, but now i cant find them anywhere on the net.
I need one of these to complete my 3" DP... i need a really tight radius bend right off of the turbine housing.
Thanks
Brian
Old Mar 17, 2003 | 05:30 AM
TurbodCX's Avatar
Default Re: 3" Down pipe Problem. (TurbodCX)
Nobody on here has bought or used a 3" donut??
How else are you making DP's?? i have alreay tried a U bend with a 5-6" radius and it hangs a little lower than my oil pan!!!!!
Brian
Old Mar 17, 2003 | 05:35 AM
Overblown-Teg's Avatar
http://www.roadraceengineering.com has them. They also have tight radius u bends. You should be able to get a normal u bend to work though. Do you have any pictures of what your working with?
Old Mar 17, 2003 | 05:47 AM
TurbodCX's Avatar
Default Re: 3" Down pipe Problem. (Overblown-Teg)
Thanks alot bro, just what i was looking for!! and it is only $55
to you!!
Brian
Old Mar 17, 2003 | 06:00 AM
Your welcome. Good luck with it. Before you buy though check the radious. I have some very tight 3" ubends from them. If it was a donut it would be smaller than a plate.
Old Mar 17, 2003 | 06:07 AM
TurbodCX's Avatar
Yeah i am going to buy the 4" radius U bend, i have a 6" now and that is what is killing me, i didnt think 6" would be to much but i guess it is,, i am going to buy the U or the Donut with the 3" radius, then i know the bend will be nice and tight, but the donut is $60 and the U bend is $35 so there is a price difference, ol' well
Thanks again
Brian
[Modified by TurbodCX, 3:08 PM 3/17/2003]
B16-CRX
Welding / Fabrication
Apr 29, 2011 07:13 AM
h22sedan
Jan 8, 2007 05:34 AM
vtec_lude
Nov 9, 2006 04:24 PM
G6-Civic
Oct 6, 2004 03:22 PM
