pre made oil return?
Old Mar 17, 2003 | 06:58 PM
ASHY-ELBOW's Avatar
Default pre made oil return?
how would these be? vs using earls with ealrs hose (i know earls would cost more)
would a 90degree to straight work? price is pretty good it says they are swivel fittings http://checkout.verisign.com/cgi-bin...9708&2D2278294
[Modified by ASHY-ELBOW, 3:58 AM 3/18/2003]
Old Mar 18, 2003 | 04:39 PM
ASHY-ELBOW's Avatar
Default Re: pre made oil return? (ASHY-ELBOW)
Old Mar 18, 2003 | 04:45 PM
RyanAutry's Avatar
TK028 (http://www.jgstools.com/turbo/t3t4oil.html)
T3 & T04 Outlet- 1/2" NPT
$11.99
EAR-981610
-10 AN to 1/2 in. NPT blue, straight, male pipe thread to AN adapter ...
$4.50
AER-FCA1003
-10 AN, 3 ft., braided stainless steel hose ...
$19.95
(2) EAR-300110
-10 AN straight, blue and red anodized Auto-Fit hose end ...
$8.50
EAR-967110
-10 AN, male, steel, natural finish, weld fitting ...
$7.69
All Part numbers are from summit except the turbo oil outlet.
If you want 45ş ends on the hose replace EAR-300110 with these
(2) EAR-304610
-10 AN 45 degree bent tube, blue and red anodized Auto-Fit hose end, for dry sump, remote oil filter line appl...
$18.50
But you can do this I guess?
$61 w/Straight Hose Ends
$81 w/45ş bends on end of hose
$102 ($51 each) for 2 oil return line kits w/ straight hose ends.
$142 ($71 each) for 2 oil return line kits w/45ş bends on end of hose
note: you can 1/2 the 3 feet of hose. That leaves 18" per return line.
Old Mar 18, 2003 | 05:17 PM
BoostedH23a1's Avatar
those look like dish washer water lines.. i wouldnt use them... go wit hthe earls like this dude said.. also heat wrap them.
Old Mar 18, 2003 | 06:43 PM
B18Flip's Avatar
Default Re: pre made oil return? (BoostedH23a1)
...i'm taking these item #'s down
Old Mar 18, 2003 | 08:08 PM
BoostedSi's Avatar
Default Re: pre made oil return? (B18Flip)
i also used the earls lines and fittings (-10an)
cpl rampage
Sep 24, 2009 06:49 AM
4cylsturbo
Aug 20, 2006 05:56 AM
importdude2000
Jun 11, 2006 10:52 PM
ultradx
Nov 14, 2005 08:13 AM
mafioso102
May 14, 2003 06:23 PM
