Need Quick Answer on Leakdown Test Results
Old Mar 17, 2003 | 06:25 AM
Holden's Avatar
Default Need Quick Answer on Leakdown Test Results
What are good and/or acceptable leak down test results for a GSR motor?
TIA.
[Modified by Holden, 10:26 AM 3/17/2003]
Old Mar 17, 2003 | 08:08 PM
Holden's Avatar
Default Re: Need Quick Answer on Leakdown Test Results (Holden)
Nobody's got an answer?!?
Old Mar 18, 2003 | 05:59 AM
SJP0tato's Avatar
You want something in the high 90% area. Depends a lot on mileage/condition of the motor, ect.
Ryan P.
Old Mar 18, 2003 | 06:17 AM
DeepSi's Avatar
Default Re: Need Quick Answer on Leakdown Test Results (SJP0tato)
you want the lowest drop in the percentage. you typically want between 100%-96% The drop in percentage is the amount of air you are losing. for example 100% means there are no leaks. 98% means 2% of the air is escaping the cyclinder tested. anything more than 4-6% is a big loose and you want to look into it. This is coming of the top of my head, but i believe those numbers are right.
Old Mar 18, 2003 | 06:31 AM
EE_Chris's Avatar
Assuming your using an input pressure of 100psi, 4-6psi is an acceptable loss.
mynameizstitch
May 21, 2009 10:13 AM
mynameizstitch
May 19, 2009 07:52 AM
91' LS-VTEC
Sep 25, 2008 07:41 AM
katoeh2o
Jan 9, 2008 11:49 AM
proda9driver
Mar 20, 2007 03:09 PM
