spoon 2 ply/copper spray
Old Mar 19, 2003 | 04:16 PM
rpm9100's Avatar
Default spoon 2 ply/copper spray
I have a spoon 2 ply headgasket, do I coat both sides with copper spray?
Old Mar 19, 2003 | 04:18 PM
Smashback's Avatar
Default Re: spoon 2 ply/copper spray (rpm9100)
Does Spoon tell you to use copper spray (only when raising your comp when using a turbo? lol)?
Old Mar 19, 2003 | 04:24 PM
rpm9100's Avatar
Default Re: spoon 2 ply/copper spray (Hatchblack)
I'm sorry I don't fully understand your reply, could you rephrase?
Old Mar 19, 2003 | 04:27 PM
Smashback's Avatar
I asked if Spoon recommends the use of copper spray. I would hope that for the price of Spoon products they should work right out of the box.
Second question...are you using this on a turbo car?
Old Mar 19, 2003 | 04:34 PM
ghettocrxsi's Avatar
With spoon gaskets you dont need to coat them.. they are already like nitrate coated..
He probably has a cheap 3 ply honda gasket that is taken apart and is using the middle..
If so then yes coat both sides with a few coats of copper spray and let it get tacky then install. That will blow if you plan on using it on a turbo motor
Old Mar 19, 2003 | 04:37 PM
rpm9100's Avatar
yes I will be using it on a turbo car
no spoon did not recomend it, my idea for better sealing?
I have a b18c5 with je 9:1 and I want a little more compression and when my machine shop cc'ed it it was at 8.75... :1 with the stock 3 ply, now it is at 9.35:1
with the spoon gasket and .015 mill. ?????
Old Mar 19, 2003 | 04:41 PM
rpm9100's Avatar
Default Re: spoon 2 ply/copper spray (ghettocrxsi)
It is definately a spoon gasket
Old Mar 19, 2003 | 06:11 PM
rpm9100's Avatar
am I asking for trouble with this combination???????????????
Old Mar 19, 2003 | 07:51 PM
Smashback's Avatar
High compression and boost is a great power making combination, but it's hard on the motor and stock Honda engines just aren't up to the challenge.
Wait until you get iron cylinders along with forged rods/pistons to raise the compression.
Old Mar 19, 2003 | 08:08 PM
rpm9100's Avatar
As I stated in my previous post, my bottom end is fully built, minus the sleeves
(JE forged slugs and eagle rods)
The compression ratio is a conservative 9.4:1 and I do't plan to boost more than 10-12psi
My original question is whether or not to coat both sides of the head gasket with copper spray or not at all.
Also I have been told that the spoon gasket seals better than the oem one???
Old Mar 20, 2003 | 01:06 PM
rpm9100's Avatar
hatchblack where did you go?
Old Mar 20, 2003 | 02:46 PM
UberTeg's Avatar
He doesnt respond in 6 hours and you think he left you? You got some child abandonment issues or something
Not everyone lives on ht some of us have jobs (not me, heh).
numero sete
May 3, 2005 12:42 PM
DC5-R
30
Aug 30, 2002 09:16 PM
